94 GMC 6.5 suburban
Old Mar 31, 2013 | 07:14 AM
mybigchevy's Avatar
Default 94 GMC 6.5 suburban
New to the site lots of info here thanks to all. I have a problem with my truck to cranks and run s then dies. After twenty or so tries if you turn key to on position and let it sit for twenty second it fires and runs. Any ideas?
Old Mar 31, 2013 | 10:07 AM
Mase's Avatar
I'm sure someone else will chime in here but it sounds like weak glowplugs.
Old Mar 31, 2013 | 12:05 PM
MontanaTechPetroleum's Avatar
Maybe bleed the fuel filter housing out, if its starting then I don't think its the glow plugs. I think you're getting fuel to the injectors to begin with then there's air in the lines and that's what causing it to die.
I have a question, how long does it run before it dies. If it barely gets to start firing then won't start then probably the glowplugs, but if it goes to idle for a second or two and then dies, try bleeding the fuel filter housing to get any air out of there.
Also have you done any work on it recently? Just any at all on the motor, this could help us understand the problem better.
Good Luck
Old Mar 31, 2013 | 01:08 PM
mybigchevy's Avatar
New glow pugs yesterday. I when to start it today started right up drove ten mins then it starting surgung. Went back home cut it off tried restarting ran 15 seciubds and died. Turned it on and waited started and stay running.
Old Apr 2, 2013 | 08:54 PM
Do you have your PMD relocated? I know mine on the extension, one of the wires broke and I did a half-@$$ splicing job on it and had those symptoms. It finally failed completely and I took my time and spliced it better and no problems since.
If you get it started, it probably not the glow plugs, once fired up, it take some really, really cold weather to kill it, (-40 F) or so where the diesel is just that cold, but I know mine will keep flickering the glow plugs on and off if its cold, even after the start.
Old Apr 5, 2013 | 07:42 PM
mybigchevy's Avatar
Mine been relocated outside on the bumper I thought about that and move it into the engine compartment but still the same. Yesterday the dealer said it was the IP but it started fine and ran fine for twenty mins then I cut it off and it won't start for three hour until whatever is getting hot cooled. Do you think me optical sensor is bad and acts up after it's hot.
Hi all thanks for all your help so far, I went out today and the truck fired right up ran for 30 minutes then died in traffic. I unplugged the optical sensor and cranked until it started up my question is how far can I go in limp mode and will it hurt anything. Can this be cleaned or do I have to replace it?
Old Apr 13, 2013 | 08:47 PM
mybigchevy's Avatar
Replace op today truck is running like dream I'm so happy
Radioking1777
Jun 8, 2015 10:26 PM
greatlakes diesel
Feb 13, 2015 09:55 PM
tedbIII
Feb 1, 2015 11:09 PM
airspeed181
Jan 19, 2015 09:00 PM
UC Kid
Oct 23, 2014 05:29 PM
