1999 Cummins 53 block leaking
Old Mar 26, 2013 | 03:04 PM
sjrvan's Avatar
Default 1999 Cummins 53 block leaking
I have a 1999 Dodge ram 2500 with the 5.9l Cummins, 141k. Started noticing small amounts of coolant leaking under truck. The truck has the 53 block, went under and saw a 4inch horizontal crack on the passenger side just below the freeze plugs. Bought Bars Leaks head gasket fix, has anyone ever tried this stuff ? I bought the one that requires no draining, I know that eventually I am going to have to replace the block.
Attached Thumbnails 1999 Cummins 53 block leaking-7690002_brl_1111_pri_larg.jpg
DirtyDiesel58
18
Sep 27, 2015 07:07 AM
PeteBug
Jun 11, 2015 12:16 PM
oilfieldguy
Feb 9, 2015 07:42 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
