7.3 no start, unplug icp then ran, then no start
Old Mar 23, 2013 | 09:27 PM
Sunrise Gardens's Avatar
Default 7.3 no start, unplug icp then ran, then no start
So........ 2002 7.3 Powerstroke, stock work truck. 244k miles. New fuel pump, fuel filter, cps sensor.
It died on me this morning a block from my house, pulled it home, checked HPOP level it was pretty empty, filled it up, still no start.
I unplugged the ICP sensor, it started right up, went for test drive, she ran awesome, then a mile away she died again. Towed it back again, I checked the level in the HPOP it was down about 1.5 to 2 inches again.
Does this mean that the IPR is bad also? Any help would be greatly appreciated.
Thank you in advance.
Adam
Old Mar 23, 2013 | 11:46 PM
strokin7.3:)'s Avatar
My 99 done the same thing and i replaced the icp and it runs great now but as far as the hpop level i can't help you there.
Old Mar 24, 2013 | 07:25 AM
So, you disconnected the icp and it ran for awhile, then died. After you replaced the icp it was fine?
Thanks
Old Mar 24, 2013 | 08:11 AM
Correct. one way to tell if it is bad is to see if oil is seaping through the plug. Also the icp should come with a new harness be sure to replace the harness and the icp.
Old Mar 24, 2013 | 08:46 AM
There is a lot of oil coming out of the icp connection, so I am guessing that it is toast.
I am going to top off the hpop again, and replace the Icp tomorrow and see what happens.
Thanks again.
Old Mar 24, 2013 | 08:49 AM
Not a problem. people help me out a lot on here. just doing the same.
Old Apr 2, 2013 | 05:43 PM
I replaced the icp - didn't start. Just replaced the IPR - didn't start. Now what?
I just stuck a ton of money into this thing and need it for work this spring, please help!
Old Apr 30, 2013 | 09:28 PM
Solution: I had bad injectors. Sent injectors to Jim at Rosewood Diesel and had premium stock rebuild, now the truck purrs like a kitten, a big kitten. Thanks for the help everyone.
Adam
Excursion73
Oct 27, 2015 05:21 PM
Bigredpowerstroke
Aug 14, 2015 10:31 AM
bajahigh
Dec 9, 2014 09:23 PM
custom7.3
Nov 23, 2014 10:44 PM
SHIFTNGEARS
Oct 30, 2014 05:40 PM
