Want to make my pickup smoke
Old Mar 23, 2013 | 08:45 PM
peterpar's Avatar
Default Want to make my pickup smoke
Ok guys im new to this and this is my first post and i have a 2001 dodge ram 3500 and i would like to make it blow some black smoke and want to know what you guys think about the best comboes or single things to do to make it smoke i also some pulling so i dont want something that just makes it smoke i also want the right stuff to make it pull much better but i also want to be able to smoke out a little box if i want to when i go thru the city but not smoke my horses out the second i hit the pedal so what are your suggestions?
Old Mar 23, 2013 | 09:32 PM
joebob3093's Avatar
Moderator
Don't be a douche
Old Mar 23, 2013 | 09:45 PM
peterpar's Avatar
sorry
Old Mar 23, 2013 | 10:01 PM
joebob3093's Avatar
Moderator
smoke is not cool, its the reason we have all the emissions stuff now days.
Old Mar 23, 2013 | 10:57 PM
diesel life's Avatar
[QUOTE=peterpar;997987]Ok guys im new to this and this is my first post and i have a 2001 dodge ram 3500 and i would like to make it blow some black smoke and want to know what you guys think about the best comboes or single things to do to make it smoke i also some pulling so i dont want something that just makes it smoke i also want the right stuff to make it pull much better but i also want to be able to smoke out a little box if i want to when i go thru the city but not smoke my horses out the second i hit the pedal so what are your suggestions?[/QUOTE
Welcome to DB
Just build your truck up to suit your needs, like for towing trailers and whatever else your truck will be used for and most likely as you build it up you will get some smoke... the goverment doesnt seem to like smoke anymore diesel smoke ciggaret smoke nothing.. nor do a lot of the guys on here like it when people just ask how to get more smoke, you normally get some sarcastic comments!!! do you currently have any mods to the truck??? i would highly recommend and aftermarket lift pump ie- airdog or fass system and a good set of guages these injector pumps dont like low fuel pressure... good luck
Old Mar 24, 2013 | 06:43 PM
minncountryboy's Avatar
Lol.. I'm keeping my mouth shut on this one...
Old Mar 25, 2013 | 05:06 AM
scottmorgan's Avatar
If you’re going to pull no more than horses I would suggest doing an aftermarket lift pump. I personally have the air dog and have had no issues with it at all. I would also get a programmer. I have the Quadzilla adrenaline with pulse v2. These are no longer being made but if you can find one they in my opinion are the best programmer. They make the most power or equal to and they by far have the most customization options. I would not get injectors. If you’re only going to pull your horses your truck can do that now. If you get a programmer you can turn down the level and not have to worry about a ton of smoke on your horses, But if you get a large injector every time you lug your engine up a steep hill or pulling hard you will smoke out your horses and you can’t turn down the injectors. The bottom line is you need a programmer for what you want. You can turn it up and run hard poor smoke out of the exhaust and then turn it down when towing your horses. You need a lift pump to supply your VP pump with enough fuel to keep it cool and enough fuel to use when you’re demanding lots of fuel for power.
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sandlappa
Aug 23, 2015 09:20 PM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
Mar 27, 2015 07:20 PM
