Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
new to 6.4 diesels
Old Mar 17, 2013 | 02:13 PM
rebel6088's Avatar
Default new to 6.4 diesels
i just got an 08 f350 6.4 auto. is there any common problems to watch for. i have a sparten tunner. afe 4'' straight pipe and stage 2 intake. my cruse controle isnt working and im gitting a code that says brake circet input b. would that cause the cruse to not work
Old Apr 2, 2013 | 01:47 PM
okie122470's Avatar
Did you try clearing the code? That should make your cruise control operational.
Old May 10, 2013 | 05:45 PM
Mike23oo's Avatar
P0703 should be the brake switch circuit. Have a trusty worthy friend check your brake lights as you hit the pedal to see if they at least work, check fuses for any blown, and if blown check wiring for shorts to ground. and last check the brake pedal switch under your foot.
Heck , the cruise control is canceled out if you hit the brake pedal.. maybe it is that switch and it's grounding out some how.
Old Aug 8, 2013 | 12:50 AM
john7fox's Avatar
yea clear the code should be okay. mine did the same thing.
there is a water separator under the driver side that should be cleaned out whenever you change your oil. its an issue for some people/
gzmak7
8
Apr 7, 2017 03:17 PM
Brushout
Jul 3, 2016 06:55 AM
dieseltuff
Apr 27, 2015 07:18 AM
Nov 26, 2014 08:10 AM
Oct 4, 2014 10:10 AM
