2001 Dodge 2500 tranny problem
Old Mar 8, 2013 | 07:19 AM
Cparsons's Avatar
Default 2001 Dodge 2500 tranny problem
I am having an issue with my tranny and thought this would be the place to ask. So my original thought is that my transmission is going out, but I would think that if it were it would slip a lot? right? but it doesn't it only has a hard time shifting from one gear to the next the only way it will shift is if I let off the diesel pedal (its not a gas pedal) ... but i was hoping some of you guys would have some input on what it might be or do just need to suck it up and buy a new tranny.
Thanks
Old Mar 8, 2013 | 07:37 AM
MillerBoyzDiesel's Avatar
sounds like your tv cable could be misadjusted.
Old Mar 8, 2013 | 08:08 AM
Cparsons's Avatar
Thanks for the info, this may seem like a silly question but where is the tv cable located? and is it pretty easy to adjust for someone who doesnt work on trucks much?
Old Mar 8, 2013 | 08:16 AM
you can adjust it from the apps. remove the plastic cover so you can watch the cable then there should be a white retaining clip thats holds the cable adjustment near the back of the bracket. push in on the clip and I would slide the cable a little bit foward and try it there. Might have to adjust a few times to get it right.
Old Mar 8, 2013 | 08:54 AM
Cparsons's Avatar
Ill check into that this weekend. thanks for your help. I have also hear that replacing the govenor solenoid and sensor in the tranny my help?
Old Mar 8, 2013 | 09:14 AM
well usually my exp. with that has been erratic shifting and/or default to 3rd at take off. Might be worth checking on scan tool.
Old Mar 8, 2013 | 09:45 AM
Cparsons's Avatar
gotchya, ill check into the tv cable this weekend and see if that solves anything
Old Mar 9, 2013 | 10:48 PM
Bryce's Avatar
Might also want to do a fluid/filter change and adjust the bands while the trans pan is off.
John Sutton
Diesel Engine Conversions
Aug 24, 2015 04:12 PM
nelly559
Feb 2, 2015 08:19 AM
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
