03 Allison issue. HELP!
Old Mar 2, 2013 | 02:06 AM
GrudgeGuy's Avatar
Default 03 Allison issue. HELP!
So one day going to work the truck loses gears. Only has park and 5th also got a check engine light. Found a bad wire to the neutral safety switch so I fixed that, clear code for a few days then the problem is back. Put a new NSS in it and still same problem. Checked cleaned and greased all connections when I did it. Made it a few miles and then the problem is back. Put another NSS in to eliminate the. Chance of a junk new part and still same problem.
What else can I do here? Anyone else been down this road before? Thanks much
BTW truck is bone stock except Edge JWA that doesn't get set above 4
Old Mar 3, 2013 | 07:43 AM
1959JD630's Avatar
Check your tcm
Old Mar 3, 2013 | 08:05 PM
Hotforteacher's Avatar
What about the NSBU?
Old Mar 4, 2013 | 09:37 PM
GrudgeGuy's Avatar
Turns out it flattened a pin when being plugged back in. Getting a new harness and a GM NSBU for peace of mind and hopefully be on my way.
Dec 10, 2019 10:10 AM
dskewes14
Sep 14, 2015 09:19 AM
JKinni
13
Sep 5, 2015 11:09 PM
Alan Scarlett
Big Rigs & Semis
Jul 23, 2015 11:19 PM
Oct 23, 2014 08:10 AM
