Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
06 lbz rear transfer case
Old Feb 28, 2013 | 02:52 PM
honda21's Avatar
Default 06 lbz rear transfer case
hey guys looking to see if anyone has put in a kryptonite rear transfer case housing from DMAXSTORE.com in there lbz. they say it's made out Aluminum instead of magnesium and will last longer even with out doing a pump rub kit. seeing if any one has had any issues. i have a small vibration around 65ish. u-joints are good and put a new out put shaft bushing inn and it still vibrates. i'm thinking the rear housing out put is egged. anyone been threw this to. thanks:
Old Feb 28, 2013 | 10:01 PM
BriteWhiteRam's Avatar
have you had an alignment lately? or maybe tires balanced properly?
Old Mar 1, 2013 | 05:34 PM
honda21's Avatar
I did a alignment and tire balance the same time i put new tires on about 5,000 miles ago. I had the vibration before all this. i got under the truck, the out put shaft has a little up and down motion in it. i can hear a little knocking in the transfer case where the main out put shaft would sit.
dezeldoc
Wanted To Buy (WTB) - Used
Jan 27, 2016 05:08 PM
Jrod89
Feb 24, 2015 09:48 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
steves2500diesel
Oct 14, 2014 05:36 PM
