7.3 won't start. HELP!
Old Feb 24, 2013 | 01:38 PM
Brett78's Avatar
Default 7.3 won't start. HELP!
Hi guys umm I got a 2000 7.3 and the other day it started acting up it would almost die then catch it self and run again it finally quit after a bit so I replaced the ecu and the ipr valve and the icp sensor still doesn't start at all. It will start on ether but won't rev up and just stalls when your stop spraying. Can any one help?
Old Mar 1, 2013 | 02:38 PM
john elkins's Avatar
do you get the wts lite when you turn on the key and starting fluid is a bad idea and can cause damage due to the high compression in a diesel motor
mine was doing the same thing and I unplugged my ICP and the truck ran great parked it and then it would not start thought I messed something up but was a fluke my fuel bowl heater shorted out and blew the #30 30 amp fuse under the dash I learned this info from this site and thats why I registerd here that fuse powers the pcm and thats why it wouldnt start
Last edited by john elkins; Mar 1, 2013 at 02:38 PM. Reason: Automerged Doublepost
Old Mar 1, 2013 | 07:54 PM
POWER-STRUCK's Avatar
did you take it in for the cam sensor recall?
Dcbb93
Nov 30, 2015 10:18 AM
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Domrig13
Dec 12, 2014 01:24 PM
custom7.3
Nov 23, 2014 10:44 PM
SHIFTNGEARS
Oct 30, 2014 05:40 PM
