fuel pump
Old Feb 20, 2013 | 11:24 AM
70GMCUMMINS's Avatar
Default fuel pump
hey all, I'm new around here and did not quite fine what i need in the search bar.
in my 1993 Cummins into 70 Gmc project, I want to run a fuel tank in the bed. do I need to run a electric fuel pump if I set the tank up to gravity feed, (as in will the mechanical pump be able to feed the FI pump)? If not what pump should I run?
I would like to upgrade later on to something like a airdog.but for now this project is eating the cash about as fast as I can make it.
thanks
Old Feb 20, 2013 | 10:10 PM
cummins bronco's Avatar
the mechanical pump should work work fine.
Old Feb 21, 2013 | 11:16 AM
Thanks for you help!
Old Feb 21, 2013 | 12:06 PM
deck60's Avatar
after replacing 3 stock lift pumps I went to this
New 140 GPH Electric Fuel Pump | eBay
works great keep in mind you want to put a screen in before the pump as it is a gear pump and you don't want anything to get into the gears
oh and the best part about this pump is when changing filters you don't have to fill the filter just crack the line on pump turn key and wait a little bit when air is all gone tighten bolt and start
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
bud0994
9
Jun 8, 2015 06:15 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Gm3500
May 7, 2015 11:01 AM
