06 5.9 starts then dies?
Old Feb 9, 2013 | 01:09 PM
Woodsracer's Avatar
Default 06 5.9 starts then dies?
I have an 06 5.9 no mods, strarted running rough while pulling 20,000 lbs, then lost power. Changed fuel filter and fcr, gained power but still running rough then it died. Now starts then dies. If you unplug the fuel sensor or regulator
it'll stay running just runs rough.
Old Feb 9, 2013 | 04:15 PM
Red_Rattler's Avatar
High Tech Redneck
Fuel sensor or regulator? Where did you find this plug to unplug it? Starts easy or got to crank a lot? How long will it run? And you mean rough but not firing on all cyclinders or? Any fuel smell or extra oil level on the dipstick?
Old Feb 9, 2013 | 05:23 PM
Woodsracer's Avatar
I can unplug the sensor on the fuel rail or the actuator on the back of the cp3. Truck starts right up. Puffs small amount of white smoke and light fuel smell from exhaust. Runs rough like one cyl not firing.
Not making any oil. Runs as long as i leave the sensor or actuator unplugged. If I start without unplugging it dies in 1 to 2 sec after firing.
Old Feb 9, 2013 | 06:19 PM
dangerous1965's Avatar
Bad injector start pulling them out! Keeps running because you max out the pressure when you unplug the FCA .
Old Feb 9, 2013 | 07:57 PM
Woodsracer's Avatar
Will the fuel sensor default it too.
Old Feb 9, 2013 | 09:42 PM
Not sure on that I think so but you can call Todd at T&C Diesel google him! Top notch fuel guy!
Old Feb 9, 2013 | 10:12 PM
Woodsracer's Avatar
Will do thanks!
thatdude38
Aug 31, 2015 05:22 PM
dshopex4
Chevy/GMC Duramax 01-04 LB7
14
Apr 15, 2015 09:40 PM
plumberjack
29
Mar 3, 2015 11:38 PM
ronstop
Feb 26, 2015 09:48 AM
DSM1988
Jan 18, 2015 11:11 AM
