difference between 2 and 3 ply tires
Old Feb 3, 2013 | 05:40 PM
hambones's Avatar
Default difference between 2 and 3 ply tires
anyone have some input on the interco vortrac all terrains? Im thinking those or the pro comp extremes? all suggestions would be greatly appreciated. also, why do the vortracs have only two plys, whereas other all terrains have three?? the vortracs have an E rating too...Can anyone explain the difference? thanks dan
Old Mar 20, 2013 | 01:27 PM
93cummins5's Avatar
There dimensions would be different and the ply is the durability of the rubber bigger the number harder and thicker the rubber is
Old Mar 20, 2013 | 02:02 PM
tiremann9669's Avatar
2 plys have 2 layers of cords in the sidewalls and 3 ply have 3 , It dosn't really matter you just need to make sure you get the correct load range for your application. It has nothing to do with dimensions or thickness of the rubber.
Old May 10, 2013 | 02:21 AM
carlod's Avatar
I agree with the above that tire ply refers to the numbers of layers of rubber materials used to make the tire. So you can assume that higher ply rating means more durable.
Kooper
Dec 4, 2015 12:03 AM
Jsully
Aug 31, 2015 07:55 PM
j_stroker
Mar 5, 2015 07:35 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
Nov 20, 2014 11:20 AM
