01 7.3l major issue
Old Jan 12, 2013 | 06:14 PM
94cummins12v's Avatar
Default 01 7.3l major issue
ok guys im working on an 01 7.3l powerstroke im doing new injector sleeves. i drained the oil and noticed an issue but wasnt allarmed yet i have a 10 quart oil pan and it only filled 3/4 and these trucks useually hold 15quart i got the driver bank all done with no issues but when i yanked the passenger rearmost injector the hole filled completly up with oil then drained into the cylander has anyone ran into this or know what could be wrong?
Old Jan 12, 2013 | 07:17 PM
95powersmoker's Avatar
When I change injectors, I pull the two back injectors first... Let them fill up with the oil that is in the oil galleys and then do the swap. Once all the new injectors are in, I pull the glow plugs and crank the truck to shoot the oil out of the glow plug port...
In your case, it is basically the same thing...
You could also get a turkey baster and a little bit of hose to suck out the oil in the cylinder.
Old Jan 12, 2013 | 07:27 PM
well im getting an oil vac tomarrow to suck out the oil out of the cylanders. so this is completly normal? just curios before i go any further. an other question i have is who ever did the injectors last put the #8 LL injector in the #2 injector hole did this do any hard or is it ok?
gzmak7
8
Apr 7, 2017 03:17 PM
Dye Guardian
Aug 1, 2015 01:28 PM
Crwln73
Jun 24, 2015 05:14 PM
akSam
15
Apr 5, 2015 01:23 PM
1988 international
Oct 24, 2014 11:36 PM
