white smoke
Old Jan 10, 2013 | 04:35 PM
bounty's Avatar
Default white smoke
white smoke under load at a dead stop. not in neutral or park. all six injectors are brand new. any ideas?
Old Jan 11, 2013 | 04:19 PM
acesneights1's Avatar
What does it smell like ? Fuel or sweet ?
Old Jan 11, 2013 | 09:42 PM
bounty's Avatar
Fuel.
Old Jan 11, 2013 | 11:33 PM
RanchhandTCR's Avatar
Generall causes for white smoke on a CTD is bad fuel filter, two weak lift pump, stiction in injectors, or injection pump. I doubt its the injector or the injection pump because it only at load not neutral, so Id check fuel pressure and your fuel filter.
Old Jan 12, 2013 | 10:14 AM
mysterync's Avatar
A pump that's just beginning to fail (timing failure) will first produce issues under load only and progress into at all times in many cases.
Old Jan 12, 2013 | 12:55 PM
bounty's Avatar
I have a bad sending unit in the tank, could that cause fuel pressure issues? My new one will be put in Tuesday.
Old Jan 12, 2013 | 01:12 PM
mysterync's Avatar
If it picks up air yea
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sgreen3
Feb 24, 2015 03:34 PM
zoomer10h
Feb 6, 2015 01:38 AM
