2000 7.3 electrical? wont start
I just can't get it running. I replaced plugs, cps, valve cover gaskets and harnesses plug relay{old and new relay doesnt have any power to the load side while key is on}, new 1000 cold amp batteries. The frame fuel pump didn't work{no power to it while key is on} untill I hot wired it then had good fuel pressure but still won't start. changed the oil, new fuel filter.....turns over fine, just wont start. im dying here.it also has got good pressure at resivor when i hot wired the pump
also, there is no power at my code reader
Last edited by edwardmcmorris; Jan 7, 2013 at 09:18 PM. Reason: Automerged Doublepost
no the wts light doesnt come on, all fuses are good
four wires that go to the drivers side wiring harness are cut. i dont know where to connect them. link to picturte
https://mail.google.com/mail/u/0/?ui....1&disp=thd&zw
Last edited by edwardmcmorris; Jan 8, 2013 at 10:02 AM. Reason: Automerged Doublepost
Can't see the picture... Post it into a photobucket account and then copy and paste the link to here... Or attach it from your computer using the post reply -- manage attachments feature...
Have you checked the fuse in the engine compartment, number 30 I believe... It controls your PCM but also controls your fuel bowl heater which is prone to shorting out and shutting down the PCM...
[IMG]file:///C:/Users/eddie/Desktop/photo.JPG[/IMG]
are these the wires needed for edge etc. installation.i just bought this thing and it wont start, then i noticed these wires.
I just can't get it running. I replaced plugs, cps, valve cover gaskets and harnesses plug relay{old and new relay doesnt have any power to the load side while key is on}, new 1000 cold amp batteries. The frame fuel pump didn't work{no power to it while key is on} untill I hot wired it then had good fuel pressure but still won't start. changed the oil, new fuel filter.....turns over fine, just wont start. im dying here.it also has got good pressure at resivor when i hot wired the pump. again, red,yellow,blue, black cut. They are leading to one of the moduleson the fire wall under the engine compartment fuse box.. No WTS light,no code reader power , no fuel pump power, no glow plug relay load side power, all fuses good.. picture on this link.
http://sphotos-b.xx.fbcdn.net/hphoto...14926870_n.jpg
Last edited by edwardmcmorris; Jan 9, 2013 at 11:00 AM. Reason: Automerged Doublepost
Excursion73
Oct 27, 2015 05:21 PM
Mac1997
Jul 13, 2015 05:08 AM
Domrig13
Dec 12, 2014 01:24 PM
