Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
TC Lock up
Old Jan 7, 2013 | 08:09 AM
scottsmith1011's Avatar
Default TC Lock up
can someone explain TC lock up and what is right or wrong.
Im running a 250el tune
Old Jan 7, 2013 | 08:14 AM
Mdub707's Avatar
What's a 250el?
TC lock up is just when the converter locks fully (think like a clutch pack) and your engine RPM is 1:1 with your trans input. So there is no slip at this point. It usually only happens once you're up to highway speeds and in your last gear for cruising. There are tunes available that can lock it up earlier and through tuning we can change at what speed it locks up. I know some of the single turbo guys have had to lock it up later (higher MPH) to stay on top of the turbo.
Old Jan 7, 2013 | 03:29 PM
250el (spartan tune im running right now). Just seems to hit Overdrive real soon after it changes to fifth. Dont like the sudden shift. Thanks
Old Jan 7, 2013 | 09:16 PM
7.3mongo's Avatar
250 and up is a race tune.. its going to shift into final drive as fast as it can. they have a 250 tow also if i remeber right..
Old Jan 8, 2013 | 09:04 AM
Mdub707's Avatar
It would actually be 6th gear, and what you're feeling is the converter locking up, you're likely already in "overdrive" aka... 6th gear on a 5R110. (What you would feel as a shift into 5th gear is really 6th, as it skips a gear on the way up all the time).
Old Jan 27, 2013 | 09:18 PM
badassfx4's Avatar
Change the tune to 250 late lock, thats what i am running in mine.
cumminspwr11
12
Oct 17, 2021 03:50 AM
TONYFERLAND
Apr 27, 2015 03:14 PM
hop sing
Feb 17, 2015 09:06 PM
Cody Cain
Dec 22, 2014 01:27 PM
Cody Cain
Dec 21, 2014 06:50 PM
