1999 v10 with zf5 5 speed to cummins 12v
Old Jan 2, 2013 | 11:50 AM
Hartford59's Avatar
Default 1999 v10 with zf5 5 speed to cummins 12v
I have a 1999 F 250 that I would like to put a cummins in. everybody says it can't be known the V 10 transmission. so I was wondering if I could put a bell housing off the zf6 or of an older cf5 that way I can still use my tranny I do not want to buy a new transmission. I see there are kits all over the place to do this walk on the zF 6 out of the powerstroke but none for the zf 5. thanks
Old Feb 8, 2013 | 12:15 PM
Buckshot927tx's Avatar
Destroked.com and Fordcummins.com have everything you need man.
Old Mar 8, 2014 | 06:05 PM
Smalldiesels's Avatar
The gasoline manual transmissions will not work on the Cummins. Fordcummins said it worked but when they tried it, it did not. Either too small of a clutch in it.
Best get one off a PowerStroke...not sure if the one off a 6.4L would work. I do know however the auto transmissions do work.
Old Mar 9, 2014 | 01:14 AM
u2slow's Avatar
Why hunt down a different trans that still needs an adapter?
Get a donor truck with the cummins, NV4500 & tcase. One stop shopping. No custom adapters. Extra goodies. Deals are out there... you just have to find them.
Old Mar 9, 2014 | 04:03 AM
timdale's Avatar
I tried the same thing, you can't get a clutch heavy enough. Also, you can't get a flywheel that has the correct tooth/pitch count to mate with a starter big enough to spin the Cummins. I went with a nv4500 and changed the input gear in my tcase to a 29 spline and it bolts right up. Also, I used a jeep 4.0 (1995) slave and works like a charm
Sent from my LG-E970 using Tapatalk
On a side note, the zf tranny has a one piece case so you can't change the belhousing. One option I looked into was a 4bt flywheel, which is close to the size of the v10. The big issue with that is finding a clutch to hold up, and I had a Hell of a time finding a flywheel
Old Mar 9, 2014 | 02:36 PM
86fummins's Avatar
I've got a 4bt flywheel on mine with a ceramic clutch and have had zero issues so far. I'm not putting out 500 horse or nothing but it is turned up.
Old Mar 10, 2014 | 09:07 AM
deck60's Avatar
your best bet is a nv4500 save the money you would spend on the adapter plates and go factory more options better clutch options and if it is a 4x4 just do this and the nv4500 is bullet proof
NV4500 Transmission 5th Gear Repair
then use the ford transfer case and and you are set
Old Mar 10, 2014 | 09:53 AM
timdale's Avatar
86Fummins, that's what I was about to do but I found a good deal on a nv, and my zf had 220k and needed a rebuild
savage-rider
Sep 26, 2015 12:43 PM
Dertyd
24
Jun 7, 2015 02:45 PM
atreefunk
For Sale
Apr 13, 2015 10:57 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
Omingnome
Oct 20, 2014 12:25 PM
