Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
HID Headlight issues
Old Dec 30, 2012 | 08:42 PM
sik6's Avatar
Default HID Headlight issues
Just got around to installing my christmas present new black halo headlights with HID'S in the low beams. I got everything hooked up and tested fine when i started the truck and turned on the headlight the low beams may or may not work and or stay on. I have the ballast boxes on the low side and could wiggle the connections between the low beams and boxes and it would may it come on or go off, but i am also wondering if the ballast boxes itself has to be grounded. The reason i ask is because after i left it alone for a while and thought about it and went back out and played a little more when i would switch from parking to headlights my radio would cut off and right back on and one or the other low beam light would come on?? Any help on this matter would greatly help thank you. Also sorry for the long post just trying to give as much info as i can. Thanks again
Old Dec 30, 2012 | 10:36 PM
mannblack's Avatar
What truck, and brand of HID kit?
Get ahold of JJ at this address:
http://www.retro-solutions.com
Ch
Sent using XT912 M
Old Dec 30, 2012 | 10:49 PM
H.R.D's Avatar
Did you install the necessary resistors and relay packs as well?
Check this thread out: http://www.cumminsforum.com/forum/3r...lutions-2.html
Old Jan 3, 2013 | 07:30 PM
sik6's Avatar
Thanks guys for the advice and input I hooked up the extra harness after reading the info that was posted and they are working fine thank you again for the help. I just have to adjust them so im not hunting for squirrels
Old Jan 5, 2013 | 02:47 PM
H.R.D's Avatar
Glad you got them working.
Old Jan 5, 2013 | 04:21 PM
mannblack's Avatar
Ditto
Sent using XT912 M
dwmeehan
Jan 29, 2025 12:13 PM
sujumptd
Jan 16, 2016 07:40 PM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
