Cummins NTC 300 Big Cam
Old Dec 19, 2012 | 07:38 AM
jedogo's Avatar
Default Cummins NTC 300 Big Cam
I have 1987 Freightliner with a 300 Big Cam.
Number 2 injector went bad a washed out the piston.
To order a new piston assembly---I don't know if it is a Big Cam 1, 2, or 3.
How do i find this information? Thanks
Jedogo
Old Dec 19, 2012 | 07:45 AM
RAW's Avatar
RAW
Call Freightliner or Cummins with the Engine Serial Number, they will be able to tell you.
Old Dec 19, 2012 | 11:21 AM
Farmboy 2.0's Avatar
Yep the serial number should be able to tell you everyhting needed about model and what not
Old Dec 19, 2012 | 06:38 PM
cummins_guy's Avatar
Give me a call, I have piston kits in stock, just have your serial number
handy.
Mike
571-230-8044
Old Dec 19, 2012 | 08:39 PM
jedogo's Avatar
Thanks a bunch. Found out it was a Big Cam IV.
Mike, I will give you a call tomorrow.
Thanks,
Jedogo
Old Dec 22, 2012 | 10:01 PM
Colotow's Avatar
cummins lives and dies by what they call the CPL number, control parts list. it's specific to each application, fr8liner, pete, kw might have the same engine but each will have a different CPL. dealers won't even talk to you without it. it's 4 digits, and will be on the data tag, usually on the front left corner near the air compressor,pump drive.
Old Dec 24, 2012 | 06:34 AM
jedogo's Avatar
I had my cpl when I ordered my parts. I have another cummins engine in a Wabco scraper, so I was aware of the cpl. I never understood the purpose of it until you said what it stood for.
Old Dec 29, 2012 | 12:47 PM
jedogo's Avatar
I now have a question about the sealant used in the liner installation. The book says to use a cummins sealant. Would a high-temp red silicone work OK?
Old Dec 29, 2012 | 12:57 PM
RAW's Avatar
RAW
I wouldn't stray too far from manufacturer specification. Liner seals are subject to a lot of abuse. Coolant and oil, pressures, expansions, heat, cold, etc. I'd use Mfg. recommended.
Old Dec 29, 2012 | 01:44 PM
jedogo's Avatar
Thanks, Sounds good to me.
wolfriver
Mar 23, 2016 10:18 PM
#cummapart
May 5, 2015 12:54 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
wpg6.5
Dec 9, 2014 10:20 AM
dross4143
Oct 9, 2014 03:18 PM
