1995
Old Dec 17, 2012 | 06:44 PM
tomt300's Avatar
Default 1995
my powerstroke starts runs great till it warms up check engin light comes on dont miss fire but it loses some power shut it off won.t restart let it set 5 minutes it starts back runs ok its like a sensor bad have changed the ipr cam sensor ip sensor that was the codes nothing helps
Old Dec 17, 2012 | 10:06 PM
tiremann9669's Avatar
If CSI were here I'm sure he could point you in the right direction. Hopefully one of the other Powerstroke guys will have an idea
Old Dec 18, 2012 | 01:34 AM
joebob3093's Avatar
Moderator
Could be an IPR issue
Old Dec 18, 2012 | 04:14 AM
MossBack's Avatar
No hot start is generally ipr pull it Nd clean it. Secondly how is the oil ? Have heard of overdue oil change causing same type of problems with oil that is sheared down to less then 30w.
Old Dec 18, 2012 | 06:45 PM
tomt300's Avatar
new ipr new oil change it as if not geting hot in asensor no smoke when try to start dose not have to set long enough to cool the engin just long enough lo let some like a sensor to cool and reset but where
Old Dec 18, 2012 | 08:07 PM
joebob3093's Avatar
Moderator
EOT sensor?
huntman7
8
Aug 28, 2015 05:42 PM
windage
Jul 17, 2015 12:45 PM
Brad.julie
9
Feb 6, 2015 04:46 AM
Dec 5, 2014 05:50 PM
7.3stroke
Oct 27, 2014 06:25 PM
