Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
Intermittent Smoke
Old Dec 11, 2012 | 01:19 PM
JDCustis's Avatar
Default Intermittent Smoke
My 2008 F350 smokes, A LOT, intermittently. There does not seem to be a repeatable pattern to when it happens. The smoke is mostly white to gray. If I shut off the engine and restart, the problem resolves itself.
I have been to the local diesel shop and the are stumped. Any ideas?
Old Dec 11, 2012 | 03:43 PM
VTstrokin's Avatar
You said that there doesn't seem to be an repeatable pattern, but when this occurs, has the truck sat in high humidity or rainy conditions before you started it? If it has, you probably need a new CAC ( Charge Air Cooler, kinda like an intercooler I believe). It could also be an injector issue.
Never hurts to Make sure the oil level is correct and not overfilled, and check to make sure you aren't losing coolant.
Old Dec 11, 2012 | 04:09 PM
JDCustis's Avatar
Too much oil can cause this? At the last oil change the tech put in 16 qts (4 gallons) not 15 because he had purchased the oil in gallon jugs. Is a quart over enough to cause this situation?
Old Dec 11, 2012 | 04:55 PM
VTstrokin's Avatar
Probably not, but it could. Overfilling oil isn't horrible, but personally I wouldn't make a habit out of it.
I would check the CAC like I said earlier. Also, check or have someone check your EGR system. It is possible that there is a crack in the EGR cooler that is allowing water to leak in.
Old Dec 11, 2012 | 05:03 PM
JDCustis's Avatar
It has an appoinment to go in next Friday for a couple of new sensors. I'll talk with the magician then about your suggestions. Thanks.
I will post results if / when we get it figured out.
burndiesel
10
Feb 7, 2023 01:15 AM
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Oct 6, 2015 10:54 AM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
gagemotors
Jun 9, 2015 04:24 AM
