1995 Gmc 2500 pops and sputters, AND TAKES OFF?!
Old Nov 27, 2012 | 06:50 AM
ebarresi5894's Avatar
Default 1995 Gmc 2500 pops and sputters, AND TAKES OFF?!
i have a 1995 gmc k2500 6.5 that, for the past couple of weeks has been popping and sputtering at idle, just for a second and clears up. so today while pulling into work, it started to do it again while i was sitting in my truck. so it popped, and while it was i gave it a little pedal and the truck took off to 5000rpm. i shut the truck off by key and it stopped. i started it up again and still pops and sputters every once and again.
please help me with this as i plow and there is a storm coming in my area.
i heard it could be PMD related??
Old Nov 27, 2012 | 03:48 PM
racer55's Avatar
Flight systems PMD's where known to cause runaway conditions because of a bad batch run in their production.
Simply put-if it doesn't say stanadyne it is a flight systems no matter who's badge is on it.
Could also be an IP problem?
There was another PMD manufacturer many years ago called SOL-D but the have been off the market for a long time.
I believe I have read about 1 grey stanadyne failing in this matter also.
This offsite thread might be of some help?
http://www.thetruckstop.us/forum/sho...ipaco+warranty
If you do contact them say the PMD is IP mounted no matter where it's actual location is.
Old Nov 28, 2012 | 10:36 AM
yea i looked at it, it had a heat sync cooler with a d-tech pmd, which i heard were garbage.
Old Nov 28, 2012 | 11:06 AM
racer55's Avatar
Dtech,dipaco,dorman,ect. are all flight systems PMD's,at one time they were very good and may be again.
But like mentioned above,they had a bad batch run that were dangerous.
Old Nov 28, 2012 | 11:57 AM
96gmc6.5's Avatar
on my 6.5 before i owned it my cousin owned it and it had a standyne pmd on it but had the high rev run away problem with it before completely quiting on him. so honestly i do not know which pmd is a good brand. do you guys know anything about the new standyne grey pmd? or the ssdiesel pmd? or heath?
Old Nov 28, 2012 | 12:07 PM
racer55's Avatar
Only 2 companies make PMD's anymore,stanadyne and flight systems.
They all fail eventually but it comes down to quality installation and the location it has to survive.
Autozone has a lifetime warranty PMD,Dorman part#904-104
Heath has a 7 year warranty kit available.
SS Diesel has terrible warranty service from what I have read and dictates the PMD be placed in the worst possible location.
The grey stanadyne has had few reported failures.
Leroy Diesel.com sells both brands and matches Heaths warranty-an e-mail to him might direct you better?
Old Nov 28, 2012 | 01:53 PM
96gmc6.5's Avatar
could you check out my problem see what you can make of it
https://www.dieselbombers.com/chevy-...-help-bad.html
Old Nov 28, 2012 | 05:09 PM
racer55's Avatar
It is best to let us find your thread on our own.
Thread hijacking is frowned upon.
