ficm programing
Old Nov 26, 2012 | 09:27 PM
badassdiesel's Avatar
Default ficm programing
hey all, i have been having some issues with hard starting and a bit of white smoke with my powerstroke, it only does this wen cold and then runs like new once its warm, i was told it was a ficm issue and am going to replace it however i was wondering . wat are my options on custom programing to run my upgrades better? thanx to whoever replies
Old Nov 26, 2012 | 10:44 PM
Karls03's Avatar
What are the ccs of your 6.0 injectors? I ask because Power Stroke injectors are usually classed by nozzle size not hp rating. Next, speaking from experience, throw that Edge into the circular file! I can trace the failure of my transmission back to that POS edge. Also, custom tuning can get more out of those injectors.
I just did the IDP FICM tune on my 2003 and I am happy with the results. Better throttle response and less smoke on spool up. There are other options, PHP has an Edge Evolution based unit that will tune the FICM and there are places that can up it to 58 volts.
Old Nov 27, 2012 | 12:03 PM
HeavyAssault's Avatar
I have read other posts that suggest the FICM tuning will have little noticeable effect since you have the modded injectors. Since FICM tuning primarly effects the pulse width the larger nozzles have the same effect. Additionally I recall the FICM tuning MAY clean up any exhaust hazing or unwanted smoke.
Old Nov 27, 2012 | 12:29 PM
Mdub707's Avatar
Yeah, test your batteries and your FICM before doing anything else. What the heck are 60hp nozzles? Did you order nozzles from a Dodge site? , sorry I had to. We tend to use real numbers when talking about 6.0 injectors, CC's (volume of injector) and a % number for nozzles over stock. So 135/stock is a 135cc injector (stock size) and a stock nozzle. Common upgrades are 175/75 (175cc's/75% larger nozzles) 190/100's etc...
Old Nov 27, 2012 | 07:33 PM
i bought them from armor inc, i told him i wanted to go bigger and he just told me they were 60hp nozzles, i know there industrial injection and one size over stock ones, were can i get these ficm programs? i live in red deer alberta. thanx for the help
Old Nov 27, 2012 | 07:54 PM
03Powerstroke's Avatar
good FICM tuning down here in Ga
Old Nov 28, 2012 | 12:04 AM
Karls03's Avatar
Sorry, I get caught up in the abbreviations sometimes. My FICM flash programmer came from Innovative Diesel Performance (IDP). Like Heavy Assault said, it cleaned up some of the smoke. Power Hungry Performance (PHP) can do a FICM flash or they sell the Edge Evolution based FICM programmers. That should get you started. I'm not sure who does 58V FICMs. Then again, I don't know if FICM tuning has made 58V conversions irrelevant.
makuloco2000
Feb 15, 2015 02:31 PM
Stroker64
6.0L Performance
Nov 12, 2014 07:32 PM
