2000 F250 - Vacuum cleaner sound ?
Old Nov 20, 2012 | 02:56 PM
angelic0-'s Avatar
Default 2000 F250 - Vacuum cleaner sound ?
Ok, stacks are on, 5" straight pipe aswell...
WTF could this be, here's a video..
It threw a code, something like ICS above expected...
Truck has a Superchips FlashPaq on it in Performance mode...
anyone got a explaination for that horrid sound.... ?
F250 Superduty - Some !#%!"# bullshit - YouTube
Old Nov 20, 2012 | 03:11 PM
Runner's Avatar
subscribing, my truck
Old Nov 20, 2012 | 03:24 PM
CSIPSD's Avatar
Its your exhaust back pressure valve closing. I am guessing your truck is cold, your exhaust back pressure sensor is plugged up.
Old Nov 20, 2012 | 03:58 PM
angelic0-'s Avatar
Doesn't matter if it's cold or hot, it happens at slow speeds at constant throttle, sound clears up as soon as he moves the skinny pedal around... decelerates / accelerates...
Old Nov 20, 2012 | 04:34 PM
CSIPSD's Avatar
Yup... Its the Exhaust Back Pressure Valve. You can try unpluging it, the plug is on the bottom front of the turbo pedistal.
Bet your issue goes away.
You can leave it unplugged if you want, or you can fix the issue (plugged EBP sensor)...
Old Nov 21, 2012 | 09:45 AM
angelic0-'s Avatar
We unplugged it today, can you point me in the right direction for a plugged EBP sensor fix DIY ?
Old Nov 21, 2012 | 09:58 AM
CSIPSD's Avatar
dajain
Mar 20, 2015 01:24 PM
Down South
Jan 9, 2015 05:44 PM
