6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Fuel Pressure Gauge Q's
Old Nov 17, 2012 | 02:31 PM
Jeff250's Avatar
Default Fuel Pressure Gauge Q's
Mornin, question....has anyone used a grease gun hose to relocate the electric sending unit for FP gauges? can Diesel corode the rubber over time?
second, this is a dumb one, when i install my adapter into the fuel bowl/filter housing will i need to perform any bleeding or air prevention action? or is there no risk while engine is off?
thanks guys. Jeff. KCCO
Old Nov 19, 2012 | 12:58 PM
Mdub707's Avatar
What is it you're trying to do? Just move the sending unit away?
Try this: Driven Diesel 6.0L Fuel Pressure Adapter
I don't think I'd use the grease gun hose myself... but I suppose it does work under pressure.
You shouldn't have to worry about it, just turn the key and let the fuel pump run for a few seconds. The beauty of the fuel pressure gauge is you'll know when fuel pressure is back up and you can fire the truck up now... haha. It's nice for changing fuel filters too.
Old Nov 19, 2012 | 02:36 PM
Jeff250's Avatar
Yeah I just wanted to locate the sender as to not interfere with the rad hose. I ended up using a street elbow to exit out of the test port metric slash 1/8npt fitting to gain the clearance. Scrapped the hose idea. Reading a solid 55 or so at wot on the gauge. Cycled the ignition three times and she's happy . Thanks.
Old Nov 20, 2012 | 09:31 AM
Mdub707's Avatar
Nice!
Old Nov 22, 2012 | 12:17 PM
Karls03's Avatar
When I had a GlowShift, the sending unit was up against the radiator hose. The Auto Meter sending unit doesn't interfer at all.
Old Nov 22, 2012 | 03:25 PM
Mdub707's Avatar
Yeah my Isspro EV2 sender hits the hose too Karl. Need to get a 90* elbow on there or something.
huntman7
Sep 4, 2015 04:49 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Jan 24, 2015 10:55 AM
