Cold Starts
Old Nov 13, 2012 | 09:27 AM
happyred1972's Avatar
Default Cold Starts
I have a 2004 Dodge 3500 (no mods other then cold air intake) the temps here have dropped down in the teens now. My question is if I do not plug my truck in it will surge and buck like crazy untill it is at running temp, then It will also throw codes like P2121 which is the TPS. (which I replaced earlier this year also)
Can anyone tell me why? This makes no sense to me at all..
Old Nov 13, 2012 | 10:17 PM
steved's Avatar
Rail pressure? Sounds like the FCA or rail pressure relief valve have an issue...
Old Nov 14, 2012 | 02:26 AM
Diesel Addict101's Avatar
Tis the season.
Old Nov 14, 2012 | 02:56 PM
newborn GOAT!'s Avatar
Default cold start
i dont have exactly the same prob or the same temp but cold starting mine for some reason for the first 10 min or so my lights will go dim back n forth... inside and out... doesnt run bad but itll do it till it warms up..
Old Nov 14, 2012 | 03:02 PM
H.R.D's Avatar
That is the grid heater cycling off and on. What does your volt gauge say when the lights are dimming? May have weak batteries or some loose connections.
Old Nov 14, 2012 | 03:10 PM
never noticed the guage moving any and i it cranks wit just a bump of the key... i havent actually put a volt meter on either one of my batteries though to see... is that normal?
Old Nov 14, 2012 | 03:16 PM
H.R.D's Avatar
Yes it is normal for the cycling of the grid heater when it is cold. Not really normal on the lights dimming down or at least not to me.
Mopar1973Man's Dodge Cummins Articles - Grid Heater
Old Nov 14, 2012 | 03:56 PM
i appreciate it!! im new to the CUMMINS game but def gettin used to it and liking what im learnin... i been owning a 7.3 since i could see over the steering wheel so its all new to me... thanks for the help!
Old Nov 15, 2012 | 01:27 AM
My lights will dim when my grid heater cycles, although im thinking the guy before me put smaller batteries in then usual the good thing is the batteries arent by any means bad they hold a great charge and the capacitor for my subs doesnt run all that much but when it does the gauge says 14.5 volts which is normal. It doesnt stall my truck out or anything quite truthfully I think ill be okay even with multiple keying cycles the battery still doesnt hesitate to turn the motor over.
Old Nov 15, 2012 | 08:32 AM
steved's Avatar
The gauge in the dash is controlled by the ECM...it will only show what the ECM tells it to show. If you put a real gauge on it, it will bounce all over the place when the grids are cycling. Lights dimming when the grids are on is completely normal.
BTW, your cycling should stop once it reaches about 3 minutes, or you reach about 25mph...
Excursion73
Sep 9, 2015 09:20 PM
dandbmcc
Mar 14, 2015 11:05 PM
91 7three
Jan 7, 2015 09:37 AM
iMixDiesel&Gas
Dec 27, 2014 09:57 PM
12vbomber
Nov 4, 2014 10:04 PM
