no acceleration, sputters
Old Oct 28, 2012 | 12:18 PM
captdevo's Avatar
Default no acceleration, sputters
Hi All!!
searched the world over and cannot find anything like this posted anywhere.
Have a Dodge 1998.5 3500 4x4 Quad automatic that will not accelerate. it starts and idles just fine, push the pedal and it spits and sputters, will not get over 1000rpms like limping.
i drove it to work, ran fine, backed into parking spot, turned it off, got out and noticed i was not back far enough. started it back up (about 45seconds from turning off) backed up and noticed check engine lite. I tried to rev it and it will only spit and sputter, but idle fine.
have not scanned for codes yet, don't think i can retrieve without tool.
Things i've done to this truck.
purchased with 136,000 miles, had been sitting for 2 years now has 195,000
when first purchased tc lockup "search" was a problem. added a filter at ecm and helped, but would not downshift. i removed the filter added a ground from batteries to engine and wrapped alternator ground with heavy foil has worked fine since.
about at 150,000 the lift pump went out, replaced with inline has been working fine, i've changed fuel filter a few times which looked fine.
since it has developed this problem i have:
changed fuel filter (looked good) bled system
adjusted apps, was at .21 sticker has .530 adjusted to .525 far as it would go.
checked and cleaned grounds, ecm plugs, apps plug
it will start just fine, just will not accelerate over 1000rpm ahen you try to accerate, it spits, sputters like crazy.
any ideas are greatly appreciated
Old Oct 28, 2012 | 12:44 PM
RanchhandTCR's Avatar
you can go to autozone and they can read the code, but if you can pull the code that would be great. But sounds like a fuel issue...
Old Oct 28, 2012 | 12:49 PM
captdevo's Avatar
have buddy with scanner here tommorrow. can't even idle this beast on a trailer, much less on the road... played hell getting across my sandy property
Old Oct 28, 2012 | 01:34 PM
Well maybe your VP44 said good bye to you... But dont go to conclusions untill you can put on a code reader and see what codes it has once you do give em to us...
Old Oct 29, 2012 | 08:06 PM
wilke12V's Avatar
i had the same issue, check codes even if the light isnt on, if there is a P216 which is injection pump timing is off/out (i dont remember exactly) i would say you vp is out check your fuel pressure at the schrader valve at idle and wot. At wot i would say no less than 7psi and thats pushing it. i had a code when the light was off. and i has the same spit and sputter, i also had a dead peddle. let us know
dawnrogerl
Oct 3, 2015 08:37 PM
jpl92
Feb 7, 2015 02:14 PM
OBSBEN
Dec 31, 2014 11:35 AM
el_gringoo
Dec 14, 2014 11:03 PM
UC Kid
Oct 20, 2014 10:06 AM
