way to much boost
Old Oct 21, 2012 | 06:00 PM
Cumberland6.5td's Avatar
Default way to much boost
Here's a little story I have to share.
A few weeks ago I broke a chunk out of a valve ( no bigger than a thumb nail ), which I found out there known for it. I replaced the valve and another one that was cracked, all new gaskets on the top end, new exhaust gaskets and valve seals.
Before I had the valve problems the truck was putting out between 8 and 12psi on the gauge, now here is the strange thing, now thats its all back together its putting out between 10 and 18 psi. 18 at hard throtle normal crusing speed it's at 10, downshifts up hill goes to 15. I have been watching the boost gauge as not to let it go over 15 to often, dont need to be picking up parts behind me.
I havent changed any settings for before, everything went back together the same as before just new gaskets so I dont know why its over boosting. No codes either.
Any idea's?
Old Oct 23, 2012 | 10:14 PM
racer55's Avatar
Do you have a turbomaster or stock wastegate controller?
What year truck?
Could be a bad MAP sensor if equipped.
Old Oct 23, 2012 | 10:29 PM
Stock wastegate. the truck is a 98 2500. If it was a bad MAP wouldn't it show a code? I put it on a dignostic and everything is reading normal.
Old Oct 23, 2012 | 10:35 PM
racer55's Avatar
More likely a bad wastegate solenoid not venting vacuum properly,I had to wait for the your answer to know what you were dealing with for sure.
A bad MAP might still be part of it though,you should have defueled from overboost or coded with a P0236 at the levels you were seeing.
Or gauge is junk?
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
