6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Water meth injection
Old Oct 20, 2012 | 10:03 PM
99stackedpowerstroke's Avatar
Default Water meth injection
So I got a used injection system off of an 03 7.3 and all it had was 2 wires a power and ground. Well the power wire was ran into the very top right fuse in the fuse panel. So I was wondering where I would run the power wire to in my 03 6.0 if anybody knows? Thanks you guys.
Old Oct 20, 2012 | 10:34 PM
Curry's Avatar
Who makes the kit?
Old Oct 20, 2012 | 11:10 PM
Um I don't exactly remember I can't look until I get home tomorrow.
Old Oct 20, 2012 | 11:15 PM
Curry's Avatar
Once you find out the manufacture you can probably get the wiring diagram for it. Or just drop an inline fuse and go off your battery. I thought they had some kind of control module to signal when to spray or a switch so you can control when it sprays.
Old Oct 20, 2012 | 11:18 PM
That's what I thought, this one has 2 wires a power and a ground, with two hoses one coming from bottle to pump and from pump to air intake
Old Oct 21, 2012 | 06:58 AM
Curry's Avatar
Id try and figure out who makes it and just get a parts list to make sure you have everything. If you do its gotta be just a toggle switch for you to control when you spray. That would get annoying though.
Old Oct 21, 2012 | 09:56 AM
Its all there. i pulled it off his truck and it worked when i pulled it off. The thing that's confusing me is that it was wired into the fuse box so it activates at wot. and now i don't know where to wire it to.
Old Oct 22, 2012 | 11:46 AM
Karls03's Avatar
If a 7.3 is throttle by wire and it was in the fuse panel, that was probably an easy 12V key on. Therefore it would have to plug in somewhere else. I use a micro switch on my Mustang that only operates at WOT for my nitrous. A similar switch wouldn't be hard to mount on your go pedal.
Old Oct 22, 2012 | 11:53 AM
Mdub707's Avatar
Yeah it probably had a toggle switch if it only has two wires... I like the progressive controllers that are boost and/or EGT referenced.
Old Oct 22, 2012 | 12:11 PM
Karls03's Avatar
Allow me to re-phrase that. I realize that you took it out, but w/o a go switch of some sort it will be ob 24/7. Select a 12V key on, route to either a toggle or WFO switch, and that should be it.
