6.5 Turbo Problems?
Old Oct 18, 2012 | 07:11 PM
GMCforLife's Avatar
Default 6.5 Turbo Problems?
Hello everyone, I'm GMCforLife. As my name suggests, I really like GMC, as I've grown up with them my whole life. My grandparents would always take us camping, and grandpa would use his 1994 GMC 3500 dually 6.5 Turbo to get us there. Needless to say, I'm in love with the truck, and still drive it to this day.
A little bit about me, I have a general interest in engines, and diesels in particular. Nothing like that diesel smell! Anyways, I don't own the truck, but there is a problem with it. The turbo seems to be going out. What exactly happens is, sometimes when I start the truck and begin driving, I hear the turbo fine, and the boost gauge reads fine, and I have normal performance. But, sometimes it will drop out of nowhere, and I can still hear the turbo, but now it sounds more airy, is the best way I can describe it. (The performance doesn't seem to suffer, but I'm not really pulling anything anyways) I'll accelerate, and the turbo will sound, but just more like air. Also the boost gauge doesn't read during this time, unless I give it a bit, then it barely reads.
Also a note, not sure if this is important or not, but I want to include every detail possible. When driving on the highway, I'll approach 65-70 and the check engine light will come on. If I accelerate past about 70, it goes away, and if I slow down below 65, it goes away as well. Not sure if this is related to the turbo.
Either way, thank you for the read, and I'm very excited to hear your ideas. I'm very new to the diesel world in terms of terminology, so if someone could point me to a great source they have where I can learn the terms/concepts, that would be very appreciated!
Old Oct 18, 2012 | 07:52 PM
Mayhem's Avatar
Check engine light comes on could be a lot of different things what codes do you get when you check it?
Old Oct 23, 2012 | 10:59 PM
racer55's Avatar
Get codes pulled and check the vacuum system out for broken lines from the vac pump to the wastegate solenoid and on to the wastegate.
Also note that boost on your truck is load dependent,if you are just cruising down a flat road-no boost is required so none is delivered-climb a hill or accelerate hard and boost should spike up to about 2500rpm and then fall like a stone again,the stock turbo is out of it's range after about 2400rpm.
Brclouse
Nov 18, 2015 08:44 AM
huntman7
Sep 17, 2015 10:03 AM
Grey Rhino
Aug 12, 2015 06:47 AM
paladin1176
For Sale
Jul 8, 2015 06:35 AM
Snoobly
Dec 11, 2014 11:59 AM
