injector test on 2006 dodge diesel
Old Oct 9, 2012 | 04:54 PM
russellflemister's Avatar
Default injector test on 2006 dodge diesel
how do i do a injector test on a 2006 dodge cummins
Old Oct 9, 2012 | 05:12 PM
cummin_un_glued's Avatar
FormerVendor
which test would you like to do? are you wanting to test the solenoids or are you wanting to do a fuel return flow test?
Old Oct 12, 2012 | 12:29 AM
Stevenlittle69's Avatar
im sure someone will chime in with a write up, but i believe for a return test you basically buy a cap tool and cap the rail individually and test the return flow on each injector. and to test the solenoid you have to send them off
Old Oct 12, 2012 | 08:19 AM
dangerous1965's Avatar
Don't do this! There is a cut out and soleniod test that the dealer can do or someone with the right tester! As for flow test they must be sent in. If it's over 100k and only running the stock filter they are probably wiped out!
Old Oct 12, 2012 | 12:16 PM
FormerVendor
You can do a flow test with them in the truck as well as checking the solenoids
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Oct 12, 2012 | 12:41 PM
voila how to - injector return flow test - Dodge Cummins Diesel Forum
BeastFromTheEast
Sep 14, 2015 02:25 PM
elbedonie
May 19, 2015 10:16 AM
Oct 24, 2014 02:50 PM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
