ccv filter delet
Old Sep 21, 2012 | 07:09 PM
pop417's Avatar
Default ccv filter delet
just did this two days ago truck seems to run much better.Got all the stuff from auto zone for under $20.00.Any else do this yet.
Old Sep 21, 2012 | 09:20 PM
baddodges's Avatar
Was it a 6.7?
Old Sep 23, 2012 | 04:30 PM
pop417's Avatar
yes i have the 6.7.filter was full of oil at 20,000 miles
Old Sep 23, 2012 | 06:12 PM
baddodges's Avatar
Did you install new ccv filter then the bypass kit. Some people gut the stock filter just to route vapors to exterior filter.im just trying to gather input before I do mine.
Old Sep 23, 2012 | 07:36 PM
pop417's Avatar
no i gutted old filter takes a little time
Old Sep 25, 2012 | 01:05 PM
chrisparsons's Avatar
hello how did you gut the old filter? the way i see this ccv filter working is oil & vapor come up thru one side of filter vapor is vented thru some fiber outlets which is vented to turbo intake or to atmosphere thru little delete kit but what about the oil is there not enough to worry about ? when you say gut the filter do you mean just remove it ? please explain. i did like pop14 got parts from auto zone then looked at removing ccv filter dont want top end full of oil
Old Sep 25, 2012 | 07:41 PM
baddodges's Avatar
Did a little research.you pry old filter apart and remove paper.then it just becomes a chamber for the gasses to go through out the exit side to exterior filter. Going to do mine this weekend
Old Sep 26, 2012 | 06:27 AM
Rail's Avatar
Could this be one of the reasons my overhead console is giving me the "get my *** to the dealer now" message? I have h&s maxx with dpf and egr deletes? I have yet to figure out how to clear the message and the dinger on startup? truck has about 43k on it and two other mechs have tried the pump the gas and break restart for the message with no change.
Old Sep 26, 2012 | 06:23 PM
baddodges's Avatar
Ok turn key on without starting. Press brake pedal twice then depress accelerator twice in less than ten seconds then turn key off. Your truck is programed to alert you at 67.500 miles of either ccv or egr cleaning
Old Sep 29, 2012 | 10:10 AM
baddodges's Avatar
Default ccv filter ?
Hey what size plug and 90 degree elbow did you buy?
