TRANNY HELP
Old Sep 15, 2012 | 04:49 PM
oilpatch welder's Avatar
Default TRANNY HELP
ok guys, 03, 5.9ho 48 r , went muddin like a dumb *** , got stuck because truck would not go in reverse, shifts thru all forward gears fine, when i put in nutral still in forward gear , when i go to reverse its like it is in nuetral, when i go to park it goes in park but feels like i trys to go forward but park dog holds it, im getting p0700 tran control module code. i check cable and it is moveing and lever on trans movewing also, trans fluid does not smell burnt , but do not have any reverse at all, everything was working fine till i wnet muddin, and was shiftin from drive to reverse to try to get out.. ok, all help welcome , thanks folks. karl
Old Sep 15, 2012 | 07:05 PM
dangerous1965's Avatar
Cable pop out of the holding bracket? Make sure it's in there right!
Old Sep 15, 2012 | 07:19 PM
Default tran
ill check that but when i was under it it seemed to be mounted secure. thanks
Old Sep 15, 2012 | 10:32 PM
If not call goerend for a honest fast answer!
Old Sep 16, 2012 | 03:42 PM
Default tran
bump, any ideas
Old Sep 16, 2012 | 08:54 PM
What does it do in park? Can you start it? Can you click thru all the forward gears? Can you start it in N?
Old Sep 16, 2012 | 10:30 PM
Default tran
it starts in park, i can manual go thru all gears, or i can put it in drive and it will gothru all its self, shifts perfect, just no reverse and nutral its still in drive, it will go in park , but seams to slighty in forward gear. i did check cable , still in bracket, took loose and moved shift lever by hand and it clicked in all positions, didnt try with truck running raining to much. thanks.
Old Sep 17, 2012 | 08:21 AM
Call Goerend sounds like a valve body issue or the rear band broke.
Old Sep 17, 2012 | 09:00 PM
Default tran
i talked to a tech at georand he said it sounded like the front clutch pack gaulded together. sent it of to tranmission shop today, i helped the guy load it on the wrecker , even with the engine off, and truck in nuetral rear end would not roll. they said they would use hd raybestos rebuild kit are they any good
Old Sep 18, 2012 | 08:34 AM
Now that is some serious overheating! I would find a shop or guy that is 48re experienced! Raybestos is ok but without the knowledge of extra hp apps building a stock unit is a waste of time! There are alot of upgrades to make it hold up! Do your homework before you throw maoney out the window! TQ, valve body and input shaft are just the mandatory things! Then extra clutch packs, GM soleniod upgrade and on and on!
