gear ratios
Old Aug 27, 2012 | 08:55 PM
Ltk's Avatar
Ltk
Default gear ratios
just looked because i was curious and my truck has 3.55 gear ratios. can someone explain what this means like power, top speed, towing, or whatever? is it good or bad?
Old Aug 28, 2012 | 06:52 PM
tiremann9669's Avatar
3.55 is a good all around gear, the higher the number the lower the gear, so 4.10 would be lower. If you did a lot of heavy towing you might want a lower gear for more power to get moving, Just an example if you're turning 2100 rpm's at 65 and you go to 4.10's you might go up to 2400 at 65.
Old Aug 28, 2012 | 10:08 PM
SCHMITTY's Avatar
I have 4.10s. If I had a further commute to work they would get old. That or I would be looking for some taller tires. Spins donuts easily though with basic mods
Old Aug 31, 2012 | 02:01 AM
Ltk's Avatar
Ltk
ok so higher the number, lower the gear? so if its higher rpms to get going for lower gearing then does that mean 3.55 would get better mileage than say 4.10? since its running at a lower rpm?
Momo12valve
12
Oct 18, 2015 04:19 AM
Jun 4, 2015 09:30 PM
bigdaddy0608
Feb 26, 2015 04:52 AM
rtbcoop
Nov 29, 2014 11:33 PM
Spiderman
Oct 6, 2014 09:52 AM
