rebuilding my own 47RE
Old Aug 26, 2012 | 11:13 PM
crusty's Avatar
Default rebuilding my own 47RE
My 2003 ram 2500 diesel has an additional transmission cooler located on the drivers side of the cab attached to the back of the block, it also uses the block coolant to transfer the heat from the tranny fluid,as well as the one at the front that is air cooled. is this one really needed as i do not tow and only do long highway trips with my truck.
I spoke with a transmission shop on rebuilding the transmission and they said they modify the pump, remove the check valve from the oil coolant line and remove the thermostatic valve from the cooler. I know of the check valve but have no idea what modifications to the oil pump is possible or where the thermostat is for the transmission that they would be talking about, has anybody heard of this.
jeremiah1
Jul 21, 2015 06:35 PM
Nu2cummins
Jun 26, 2015 02:30 PM
cumminsbred01
Feb 26, 2015 08:49 PM
DODGEARMYGUY
Feb 8, 2015 07:08 PM
Rx7man
Jan 11, 2015 08:44 PM
