Cranks But Won't Fire
Old Mar 2, 2008 | 03:17 PM
06 DIESEL's Avatar
Default Cranks But Won't Fire
Here is the situation, I went to start my truck to take it over to a buddies to hook up the FP gauge again, (needed a new fitting after the Air Dog install) and it won't start. It started to fire then I stopped cranking and it shut off. Now it only cranks but will not fire. I tried to hook up my smarty for codes but it will not connect, not sure why but it keeps telling me to turn the key off, then on, then says connecting, then back to the key thing. The Air Dog is not pumping anymore, normally you could hear it when you first kicked the key but now it just sits there. The key trick has never worked for me, not sure why but I have never gotten it to work. There are no fuses blown, nothing unhooked, everything looks good. Anyone got any ideas?
In the last month or two I have added the Air Dog, SB DD 3600# clutch, and Smarty. Truck has just over 31k on the clock now and it ran fine yesterday, no signs of anything on the way home last night.
Any ideas?
Old Mar 2, 2008 | 04:58 PM
Whit's Avatar
Site Mascot
if the airdog aint runnin then yer not getitn no fuel...........sounds like a wiring issue with the airdod so start searchin there
Old Mar 2, 2008 | 05:21 PM
DazedandConfused's Avatar
Remeber though once you have primed the system until you loose prime again it will not kick on. With the smarty not being able to read the ECM I'm thinking you have blown a master fuse to the ECM or your ECM died.
Old Mar 2, 2008 | 05:59 PM
06 DIESEL's Avatar
Got it to start, there was a bad ground on the drivers side battery.
Old Mar 2, 2008 | 06:00 PM
Whit's Avatar
Site Mascot
sounds good man.......I can hear it from here
Strangeak
Jun 19, 2015 11:07 AM
biged681985
For Sale
Apr 28, 2015 04:26 PM
rattletrap
5.9L CR Performance
Mar 1, 2015 06:48 PM
Mike H
Jan 25, 2015 10:08 AM
Sep 29, 2014 03:00 PM
