how do i ckeck my ignitio switch
Old Aug 17, 2012 | 09:58 AM
bad1972's Avatar
Default how do i ckeck my ignitio switch
Hi folks I have 95 GMC 1 ton 4x4 PMD went out i replaced it ! Now the WTS light or none of the other lights in dash isnt working ! Cleaned all the grounds and cables ..It cranks, headlighs and haards work ,but wont start and no turn signals . The only thing i can think of is the ignition switch or would the EMC cause the same effects ? Any help would be greatly appreciated
Old Aug 17, 2012 | 11:49 AM
Mayhem's Avatar
Check ign B fuse under the hood if bad then more than likely you have a bad ignition switch or a open short somewhere
Old Aug 17, 2012 | 08:59 PM
bad1972's Avatar
Ive checked all the fuses ! what do you think about ECM ?
Old Aug 17, 2012 | 09:01 PM
Mayhem's Avatar
have you tried pulling codes yet?
Old Aug 18, 2012 | 12:56 PM
bad1972's Avatar
no i dnt have a code reader ! i found ground for ECM under dash was lose thought that might have been it, but no such luck !
I took my first ride in 2 months !!!!! It is the ignition switch i took cover off botom of switch crossed red wire over to pink wire everthing started working fired right up !!!! thanks Mayhem for your help
Old Aug 18, 2012 | 02:14 PM
Mayhem's Avatar
NP bad1972 I am a G.M. guy and I have had a buttload of G.M. vehicals myself and worked in after market part sales for a few years and I can't think of a time that I or someone needed a ECM for a G.M. vehical sold a few to people after they or a "mechanic for 20 year friend" and the ECM was never the problem I know nothing lasts forever but I have yet to run across a bad G.M. ECM ty
cumminspwr11
12
Oct 17, 2021 03:50 AM
rstrange1996
Sep 22, 2015 01:25 PM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
Cody Cain
Dec 21, 2014 06:50 PM
IslanderXJ
Dec 17, 2014 04:14 PM
