99 6.5 turbo diesel
Old Aug 9, 2012 | 04:54 PM
duckslayer31's Avatar
Default 99 6.5 turbo diesel
what upgrades can i do to make the turbo spool louder and spool closer to idle and what can i do to make her blow a little more smoke?
Old Aug 9, 2012 | 05:08 PM
Mayhem's Avatar
if you still have the stock turbo you can forget about making it louder ive been told a
C7 Catapiller turbo will bolt right up on a 6.5 and the spool up quick as for smoke a number 9 resitor will make it smoke a little bit more under accelleration
Old Aug 9, 2012 | 08:19 PM
Hoffy85's Avatar
will the Catapillar turbo put out more boost?
Old Aug 9, 2012 | 08:50 PM
Mayhem's Avatar
yeah from what I was told and it spools up faster and has a good sound compared to the G.M. turbos which as we 6.5 owners know barely make any sound if and when my turbo takes a dump a C7 is what I will be putting on my truck
Old Aug 10, 2012 | 07:25 PM
ebarresi5894's Avatar
Holset hx40 from what I heard will work too.
I would put a 5"exhaust bigger crossover bigger down pipe and turbo master will make it sound good. Also check your intake manifold plenum it can have a rubber guard in it.
Old Aug 13, 2012 | 10:37 PM
the rubber guard? do i take it out? and will it hurt anything?
also as far as the c7 turbo goes will it produce to much boost? ive hurd it can blow heads?
Last edited by duckslayer31; Aug 13, 2012 at 10:37 PM. Reason: Automerged Doublepost
Old Aug 14, 2012 | 03:11 AM
Mayhem's Avatar
Yep you can take out the rubber gaurd and no it wont hurt anything,and no the C7 should'nt pust too much boost if it were to do so the truck would go into limp mode and to combat that you would have to a turbo master and that would take care of the problem.
Brclouse
Nov 18, 2015 08:44 AM
Dye Guardian
Aug 1, 2015 01:28 PM
MrMoose
Mar 15, 2015 06:05 PM
Snoobly
Dec 11, 2014 11:59 AM
Oct 24, 2014 04:40 AM
