NEWBIE!!! LOSS OF POWER WHEN I STICK MY FOOT IN IT!!
Old Aug 9, 2012 | 02:02 AM
PBNITRO898's Avatar
Default NEWBIE!!! LOSS OF POWER WHEN I STICK MY FOOT IN IT!!
FIRST TIMER HERE AND BEEN READING FOR THE LAST FEW WEEKS AND TRYING DIFFERENT STUFF THAT IVE READ ABOUT....
2005 DODGE DIESEL 5.9 CUMMINGS........ STARTS GREAT RUNS GREAT BUT WHEN I STICK MY FOOT IN IT TO PASS OR ACCELERATE IT BOGGS .......RUNS FINE UNTIL IT HITS ABOUT (2000 - 2300) RPMS THEN CUTS OUT TILL I LET MY FOOT OFF THE GAS........NO BUCKING OR JUMPING JUST ACTS LIKE ITS KICKING IT INTO LIMP MODE OR STARVING FOR GAS......
THE THING THAT IS GETTING ME IS IM GETTING NO CODES ANY WHERE....... HOOKED IT UP TO A SCANNER AND NOTHING..... EVEN WITH THE TURNING THE KEY ON AND OFF THREE TIME TRICK I STILL GET NOTHING......NO CODES........
ALWAYS HAVE CHANGED MY FUEL FILTER WHEN I CHANGE THE OIL.... BUT JUST PUT A NEW ONE IN JUST TO TRY..... CHECKED ALL MY BATTERIES THINKING I MAY BE HAVING A BAD GROUND ISSUE SAW NOTHING THERE.......
JUST ORDERED A NEW FCA..(FUEL CONTROL ACCTUATER) HOPING THAT MAY BE THE PROBLEM....... NEXT I GUESS WILL BE THE LIFT PUMP??????......BUT I HATE TO HAVE TO DIG INTO THE TANK TO MESS WITH IT...... BUT I WILL IF I HAVE TO......
ANY HELP WILL BE GREAT.......
HELL I EVEN THROW IN A GUIDED BASS FISHING TRIP TO THE CA DELTA IF SOME ONE CAN HELP FIX ER UP.......
Old Aug 9, 2012 | 08:16 AM
dangerous1965's Avatar
First get a gauge hooked up to the delivery line to the CP3 that will tell you fuel pressure
at full throttle. A rail pressure gauge would really help!! Next unplug your FCA for a few seconds what did it do? Can't wait to go fishing!
Old Sep 1, 2012 | 09:20 PM
12 valve and proud's Avatar
Have you adjusted your front transmission band?
Old Sep 4, 2012 | 05:05 PM
PBNITRO898's Avatar
OK IM BACK...... AND YES I HAVE ADJUSTED THE FRONT BAND ON MY TRANNY......
I INSTALLED A NEW AIR DOG SYSTEM..... BUT STILL NO CHANGE.....
I HAVE GOOD FUEL PRESSURE AT THE RAIL AND ON THE LOW PRESSURE SIDE......
NEW (FCA)..... STILL NO CHANGE....STILL NO CODES
STILL DRIVES JUST FINE.... STARTS FINE..... IDLES FINE...... BUT AFTER I STICK MY FOOT IN IT WITH IT IN GEAR....ONCE IT GETS UP THERE IN THE RPMS IT BOGS OUT.... CUTS OUT..... LIMP MODE IS KICKED IN...... STILL DONT KNOW.....
ORDERED A TUNER/PROGRAMER SO I CAN SEE A LITTLE BETTER AS TO WHAT ELSE MIGHT BE GOIN ON.........
ANY IDEAS.........ONE THING IM NOT SEEING WHEN I TRY TO ROMP ON IT IS BLACK SMOKE LIKE NORMALLY...... HOW DO YOU CHECK YOUR TURBO..... EVEN TRYING TO POWER JACK IT IN MY DRIVE WAY NOT GETTING ANY EXAUST SMOKE.....
WHY NO CODES.......L;OLOLOLOL..... GOTTA BE SOMTHING SIMPLE RIGHT...???
LOVE WORKIN ON MY TRUCK BUT THIS IS GETTIN OLD!!!!!!.......
Old Sep 4, 2012 | 10:30 PM
No codes with Limp mode on? HMMM Going to have to wait for more info when you get your tuner. Something is not reading right causing the engine to protect itself It's either air or fuel!
Old Sep 4, 2012 | 11:06 PM
superjoe83's Avatar
check your intercooler, some 2005's had plastic tank intercoolers that are known to blow out, i recently had to replace one in a friends 05
Old Sep 5, 2012 | 10:01 PM
CHEMMINS's Avatar
Check the throttle position sensor.
Old Sep 5, 2012 | 10:08 PM
Check your tranny and exhaust sensors
X2 on checking the TPS
Old Sep 10, 2012 | 10:24 PM
PBNITRO898's Avatar
OK GOT A NEW...TPS.... STILL DIDENT WORK
..... GOT THE SMARTY HOOKED UP AND SAYS IM LOOSING BOOST WHEN I ROMP ON IT...... BOOST LEVEL IS JUST FINE CRUSING AROUND BUT WHEN I ROMP ON IT THE READING DROPS DOWN TO NEAR NOTHIN........
TURBO GOING BAD???
WASTE GATE STUCK ????
INTER COOLER BLOCKAGE?????
ANY IDEAS.....
ALL THE OTHER GAUGES AND READINGS ARE LOOKING NORMAL
Old Sep 10, 2012 | 10:34 PM
1999stroker's Avatar
Check your shaft play. Also check for boost leaks.
Sent from my DROID BIONIC
