exhaust brake more plausable
Old Aug 4, 2012 | 06:38 PM
Twebb833's Avatar
Default exhaust brake more plausable
Tell me if this makes sense. I will use the IVS signal as a remote for a normally closed relay then from the power out going to a 3 position switch to the EBPV. Up position would be automatic. Down would be manual. This way when i am pushing on the pedal it is sending voltage to the relay OPENING it not allowing the ebpv to shut but as soon as i let off it cuts power and in return sends power to the ebpv.
The IVS is 0v at idle correct?
Old Aug 4, 2012 | 06:49 PM
joebob3093's Avatar
Moderator
I just wired mine to a switch. Off and on, don't need to make it complicated.
Old Aug 4, 2012 | 06:59 PM
Twebb833's Avatar
Im a complicated guy. I already have it wired to a switch.
Old Aug 4, 2012 | 07:02 PM
joebob3093's Avatar
Moderator
Good luck
Old Aug 4, 2012 | 08:24 PM
Twebb833's Avatar
Haha thanks! Maybe one of these days ill get bored enough to screw around with it...
Old Aug 4, 2012 | 09:12 PM
twinboys's Avatar
From a logic standpoint, go through the switch first.
one position powers ebpv directly ---(on)
next position goes through the ivs (or brake pedal) triggered relay--- (automatic)
last position goes nowhere ---(off)
Momo12valve
13
Nov 9, 2015 09:54 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
charlie175
Sep 1, 2015 04:01 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Turbo67
Jul 25, 2015 02:26 PM
