Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
Puttin Up Pole Barn.
Old Feb 29, 2008 | 05:38 PM
I-6DZL's Avatar
Default Puttin Up Pole Barn.
Pole barn is going to be 24x40. Ceiling depends on how much clearance i'm going to need for a 2 post 10 - 12k lb. hoist. I'm going to have a ton of questions. This is the 4th building i've helped put up, but this one is going to be mine.
CONCRETE -
What type do you think i'll need ? Fiberglass reinforced ?
How deep ?
I will have a concrete patch leading to my 2 10x10 overhead doors. same questions apply here. I realize i don't want to bring out 2 different types of concrete.
concrete will be dropped off by pro's, and i will finish. Need hints and help here especially.
ELECTRICITY -
I'm going to have a hoist in there.
Wire welder.
Plasma cutter 120v
Air compressor 220v - anybody got a good deal on one ???
Misc lights and normal good stuff.
Will NOT have a furnace. just a wood stove that is enclosed and has a forced air fan on it - 120v.
OVERHEAD DOORS -
2 - 10x10 doors. Need advice on the best way to frame these in, and have everything turn out and look great.
I will have a sliding door on the back side leading into my hoist. Slider will probably be 14' long and depending on the ceiling height, probably 12' high.
BATHROOM
When finished, will have a shower, toilet, sink, and wash basin. (deals on these items too?)
I know i'm forgetting alot of stuff, but i'll update as i go along.
If anyone knows of any deals on lights, electrical wire (both 120 and 220v) I live in MI, so it would need to pretty close to be worthwhile.
I'm building this on a very limited budget, and have 95 % of the building materials purchased. So i'll need to get the building put up and finished off before the purchase of accessories.
Thanks everyone i appreciate your insight.
Old Feb 29, 2008 | 06:10 PM
Whit's Avatar
Site Mascot
read this while I try to answer some of yer questions
https://www.dieselbombers.com/shade-...op-7-days.html
Old Feb 29, 2008 | 06:23 PM
Whit's Avatar
Site Mascot
CONCRETE -
How deep ?
I have poured over 7k cu yd of concrete in my 6 short years of bisness and had 11 peeps workin for me.................I got the concrete biz down pat
Myself I would insure a real good road base and moisture content then rent a compactor and get it real tite
I would pour a 5.5 -6" concrete 6 bag mix with no fiber mesh
for the posts anchors a 5 bag mig will be sufficient
you will hafta do a seperate batch of crete for the posts anyway so they will be set up and cured b4 ya pour the floor
you say you will have pro's drop it off and you will finish???
you will need a shoot man, 2 rakers and 2 screaders and one other on the bullfloat...........my advice here is for one of these dudes to know what he is doing and not just a weekend rendezvous kinna guy................if you dont then you will end up with a mess and hafta live with that the rest of yer life
also you will need to rent a 30-36" power trowel and someone needs to know how to run that and know all the tricks to the trade
62*f is the optimum concrete curing temp
donot drive on yer new floor for a minium of 7 days
Old Feb 29, 2008 | 07:38 PM
jstange2's Avatar
Would you use 6x6 wire mesh or 2 ft on center 1/2 inch rebar Whitmore?
I-6DZL
I think most hoists are a minimum of 12 ft ceiling.
You should also think about some type of permanent heat source if you are going to run water in there unless you will be able to babysit the wood burner several times a day in the deep winter (Just to keep it above 45*).
If your doors measure an actual 10'x10', you should be able to make your rough opening 10'2" wide and 10'0 1/2" tall (from top of concrete). Then you will nail a 2x to the R.O. that extends beyond the front of the purlins at least 1 1/2 inches (probably a 2x10 asuming it is a polebarn with vertical steel finish) which would make the finished door opening 1 inch smaller both directions (the 2x will be wrapped with metal before the steel is installed).
I would assume the very smallest you could go for an electrical service would be 200 amp.
That is all I can think of. You probably already knew some of it, but hey, hope I helped some.
Josh
Old Feb 29, 2008 | 08:34 PM
IC Smoke's Avatar
Curtis
I can bring up my equipment, I have access to a lazer transit, walk behind compactor and "Vibra-strike" (12' head), and concrete tools. Free and clear! I did flat work (the tree svc was excavation and flat work) for 5 years along with Chris whom did it full time for over 3 years in the Saline area. we can help ya get the mud poured no problem!! I dont have access to a power trowel but Im sure we can find someone with one
If ya need anything just let me know and Ill be up in 45 min!
Old Feb 29, 2008 | 08:40 PM
I-6DZL's Avatar
I've read through, studied pic's about 20 times. I can only hope mine comes out half as well as yours.
CONCRETE -
How deep ?
I'll be honest with ya, my extent of concrete knowledge could fit on a pencil eraser.
when you say a "6 bag mix, or 5 bag mix" you mean how much concrete per however much water content ? The "pro's, will just drop it off" I will have at least 3 other guys besides myself dragging concrete, and floating. As far as power floating, i've never done it, but i've seen the machine. What exactly does it do? Tighten the concrete and get most air bubbles out? I've spred crete on my inlaws barn, and my late fathers barn. We didn't power float either of them, and only my inlaws is starting to slightly crack after 6 years. We poured 6 to 8" cant remember. When i pour will i have to partition off each separate slab ?
I-6DZL
Josh
It will definately be a vertical polebarn finish. I was thinking about the water idea, and not sure on that as i won't be able to afford the propane to keep at a constant 50 degrees or so! the barn will be insulated with r13 in the walls, and about 2" polystyrene to finish off the inside.
i know i'll need 200 amp service in there also, but could i get away with feeding the barn off the main service from the house so i can backfeed with a generator when power goes out ?
You both have been more than helpful, and can only cross my fingers on how this turns out! Yes i'm a weekend warrior with many skills, just no tricks of the trade YET!!!
Thanks again
Curtis
Originally Posted by IC Smoke
Curtis
Damn man i didn't know this about you, or Chris even HAHA. That would be sweet if you guys could give a hand. Do you have access to a tractor/hoe that we can level everything with and dig a trench for the sewer ? I'll owe ya big time!
Old Feb 29, 2008 | 09:07 PM
Whit's Avatar
Site Mascot
wire mesh nor rebar will be needed for a pole barn...........unless ya wanna run semi trucks or the likes thry there
sounds like you have a good hookup on crete guys
yes when I talk of 5 or 6 bag mix that means how many bags or cement per yard
Old Feb 29, 2008 | 09:11 PM
I-6DZL's Avatar
Sweet you da man!!! Thanks bud
Old Feb 29, 2008 | 09:12 PM
Whit's Avatar
Site Mascot
I have had it and headin to bed but I will check in tomorrow on this............makes me wanna do another one
Old Feb 29, 2008 | 09:53 PM
LOGANSTANFORTH's Avatar
yes, you are gonna need a 200 amp service, make sure you got 110 outlets every 6 feet, in a house you got 6 plugs to a breaker normally, in a shop, i would do no more than 4 cause of the tools your running, on the 220 you will want all dedicated circuits to your machinery, use 220 where ever you can, welder, fans, air compressor, anything and everything, IT WILL SAVE TONS OF MONEY IN ELECTRICAL BILLS, the cost difference will be covered in the first year easily, yes you can also feed the box with a line from the main house if need be, i wouldnt power the whole shop, just the heater blower, some of the lights and a few plugs........and i would also recommend sawing the concrete too cause that will help stop cracking.......
