Water Meth??
Most water/meth controlers are boost referace, above your preset boost point the water comes on. Some also have a EGT referance as well.
I have my first stage set to come on at 10psi and second stage at 25psi. I dont like the EGT based systems, because there is always a chance of spraying when you dont have boost which can cause issues with hydrolocking.
Water/meth should not be looked at as a HP boost like nitrous, its better to look at it as a added intercooler.
They all have controlers with the kits, I prefer coolingmist to snows. Cooling Mist has better pumps, better nozzles and better controlers. Its just a better kit and much better people to work with.
Water Injection, Methanol Injection, Alcohol Injection Systems | Coolingmist
On a PSD, keep it below 40% meth unless you want to see what the inside of the block looks like.
Lawrence D. Sanders Sr
5.9 Liter CR Dodge Cummins 03-07
Dec 16, 2014 11:52 PM
