6.2 vs 6.5 Perfect Build
Old Jul 29, 2012 | 11:42 AM
cviola2005's Avatar
Default 6.2 vs 6.5 Perfect Build
With the 6.5TD out of my truck, I have been looking for a replacement. I went to look at a 6.5TD from a 96. It won't start so I didn't buy it. After returning home and searching for another engine, I found a 6.2 engine for really cheap, so i picked that up.
IIRC, somewhere I read said that a 6.2 bottom end with 6.5 heads and turbo will run like a raped ape.
I'd like to hear everyones opinion on what combination of parts between the two engine will work the best together. Or last longer. Thanks
Old Jul 29, 2012 | 12:48 PM
Mayhem's Avatar
Congrats Civiola hope you get that rig up and going soon where and how much was that 6.5 you looked at ???
Old Jul 30, 2012 | 01:50 AM
cviola2005's Avatar
buddy of mine in cookeville, tn. kenny's auto salvage. he quoted it to me for $800 b/c we've been friends for several years. if you want it, let me know.
Old Jul 31, 2012 | 02:54 AM
cviola2005's Avatar
I've pretty much decided to keep the bottom end of the 6.2 alone and keep the stock heads on it. all i will use from the 6.5 will be: injection pump and injector lines, intake and exhaust manifolds, water pump, oil pump drive gear, and all serpentine accessories.
I have been told that the injector in the 6.2 heads are at a different angle than the 6.5 injectors. I decided to check that out. I installed two injectors into the 6.2 heads and partially installed the 6.5 injector lines for those two cylinders. Although the picture below is not that clear (sorry), it is still noticeable that the difference is minute. I believe I will installed the lines to the injectors first, and then tweak them to fit the injection pump.
MIBoondocker
Jun 20, 2015 11:56 PM
JamesL91
Mar 15, 2015 06:11 PM
jtwthaxj
Diesel Engine Conversions
Jan 14, 2015 06:52 AM
Caveman94
Dec 8, 2014 12:21 PM
Nov 7, 2014 12:00 PM
