05 high egts
Old Jul 29, 2012 | 01:39 AM
59cummins67's Avatar
Default 05 high egts
hello i know this topic has probably been brought up before but i need some input. i have an 05 2500 4x4 6spd manual with an edge juice cs model and K and N airfilter other than that its stock. my problem is when i first started running this my egts were fine and the truck barely emitted any smoke.but now my egts are higher and im seeing more smoke out of the exhaust. i have the egt probe in the exhaust manifold. besides changing the turbo what could i do to best help with the high egts? ( trying to find inexpensive ways to help with this at the moment until i can afford more expensive means)
Old Jul 29, 2012 | 12:26 PM
cummin_un_glued's Avatar
FormerVendor
how long are you talking that it was from the egts being fine to them being high? also how high do they get?
Old Jul 29, 2012 | 12:38 PM
dangerous1965's Avatar
Filter clogged K&N not so good for diesels
Old Jul 29, 2012 | 04:26 PM
it started about a month ago i could run the programmer on level 3-4 just fine but now i cant even run level 1 with out it blowing smoke and instantly jumping between 1400 and 1500 degrees. im going to try and change the fuel filter
Old Jul 29, 2012 | 10:57 PM
FormerVendor
Id check that first
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Jul 30, 2012 | 09:50 AM
Originally Posted by cummin_un_glued
Id check that first
I meant air filter clogged!
Notdaddysmoney
11
Oct 23, 2015 12:52 AM
CumminsCoalRoller24/7
May 25, 2015 09:04 PM
Moparts345
May 24, 2015 09:35 AM
Curry
Apr 20, 2015 04:04 AM
robbyS
Apr 16, 2015 02:22 PM
