t case for nv4500
Old Jul 27, 2012 | 06:18 PM
codycatract's Avatar
Default t case for nv4500
sorry for making another post i didnt know how to change title from previous post to this but anyway my powerchoke is going on down hill so im trying to just get the cummins going in it. i am going to be using nv4500 and will eventually be running np271 with 29t input, for now i wanna know what t case will bolt right up easy to find and not tooo expensive??
And is there a vender that sells ford clutch pedal assembly for a gas or idi mid 90s?
Old Jul 30, 2012 | 09:09 AM
93_Fummins's Avatar
The clutch pedal assembly will likely have to be a Pick-N-Pull junkyard part...I've never seen them available off any shelf, personally.
If you're putting a Cummins in it, just find a rusted out 4x4 Dodge and use the whole drivetrain. The 2nd Gen t-case (241DHD most likely) falls to the driver side like a Ford, so it should be just fine. If you already have the engine and transmission, then look around for a 241DHD from behind a Cummins/NV4500 combo. The 29 spline output on the NV4500HD kind of drastically narrows down the available t-case options to either a factory available one or a hybrid/adaptor of some sort...
Old Jul 31, 2012 | 09:12 PM
so most people that have the nv4500 usually have the 241dhd? and it hold up fine?
So for my nv4500 what year np241hd are compatible? And are they interchangeable from auto and Manuel tranny?
Last edited by codycatract; Jul 31, 2012 at 09:12 PM. Reason: Automerged Doublepost
Old Aug 1, 2012 | 09:08 AM
93_Fummins's Avatar
I haven't heard much bad about the 241DHD other than lack of a SYE...
IIRC, you will have to find a 241 from behind a manual (V10 or Cummins) to get the 29 spline count, the V8 NV4500 and auto's are 23 spline...?
Old Aug 1, 2012 | 09:20 PM
just as long as its 29 spline right? the bolt patterns are the same on all of those? does this seem like a decent t case to go with, for towing 10,000 pounds across state from time to time? i dont wanna have any regrets
Old Aug 9, 2012 | 07:41 AM
So the np 241is a common one to run?
Old Aug 24, 2012 | 09:15 PM
timdale's Avatar
I put a 29 spline gear in my ford 273 and the getrag bolted right up, nv4500 will do the same
Old Aug 25, 2012 | 08:30 PM
What year ford? Would my borg Warner boltup if I did 29 spline? Or am I able to get 29 spline for that t case
Old Aug 26, 2012 | 05:09 AM
timdale's Avatar
It's a 99 super duty. Not sure if they make a 29 spline gear for the b/w. The main reason I did it this way is I couldn't find a 241dld for the life of me, except one and the guy wanted $800! $170 for the gear and 1 hr to install it and I was in business
Old Aug 26, 2012 | 11:36 AM
Did you get the hear through advanced adapters
