Spacer plate
Old Jul 26, 2012 | 03:10 PM
97powerstroker's Avatar
Default Spacer plate
I'm in the middle of putting a 5 speed in my truck an when i pulled the tranny out of a donor there is a spacer plate behind the flywheel that the started bolts to an such. Now when i pulled out my e40d i noticed that it had the same spacer. I was told that i need the one off the manual truck but to me they look exactly the same. So can i use the one from my auto or do i grab the one off the manual
Old Jul 26, 2012 | 06:17 PM
codycatract's Avatar
did you already put pedal assembly in? cerious how that part was, im gunna be doing the same thing? drill hole in fire wall and stuff?
Old Jul 26, 2012 | 06:20 PM
i havent gotten that far yet but im pretty sure you dont drill any holes
Old Jul 26, 2012 | 06:39 PM
jamesrett's Avatar
I just put a 5 speed on a auto motor myself. I used the spacer that was on the auto motor and all went well. Good luck. Any other questions I'll try to awnser them. Thanks
Old Jul 26, 2012 | 07:53 PM
fordornothing's Avatar
no need to drill holes... the pedal assembly is all one unit. there is a plate next to the brake master for the clutch master...
Old Jul 26, 2012 | 09:17 PM
Hey thanks guys! and ill be sure to ask but it seems pretty straight forward
Old Aug 21, 2012 | 09:04 PM
throttle body spacer? he's talking about between the engine and trans...
Flikkie2001
Jun 26, 2015 12:53 AM
SMatyac
Nov 15, 2014 07:35 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
hardeercy
Nov 6, 2014 08:08 PM
12v_freak
5.9L 12V Performance
9
Oct 10, 2014 02:33 PM
