Questions on Mods
Old Jul 26, 2012 | 07:22 AM
scubadilla4545's Avatar
Default Questions on Mods
Grid Heater delete....will that affect anything to do with my heater or does it just allow for more air flow?
When I took the valve cover off today I noticed what was called a coalescer assembly that has to do with emmissions filtration. Since I did my deletes do I still need this in there?
I can't afford some good head studs now and I still feel doing that myself is above my pay grade but what about adjusting injectors I believe to .20 Are there any videos or how to's on that, what kind of tool do you need to do it?
Old Aug 5, 2012 | 08:36 PM
BigBlack2011's Avatar
The grid heater serves basically the same purpose as glow plugs used to in older trucks it just heats the intake air prior to startup so it may not affect your heater directly, but deleting it will cause you're engine to reach operating temp a little slower but not much. What you're calling a coalescer is actually the CCV or crank case ventilation filter and no. You don't need it. It actually vents into the intake which has been known to cause an oily build up on the compressor wheel of the turbo. They make kits to delete the CCV filter any diesel store will sell them.
I installed my own studs and it's really not that bad. Just time consuming, I'm not sure on the valve specs but I know that I was told not to set the lash any tighter than factory. I want to say .12 and .24? Don't hold me to that. Hope this helps!!!!
Old Aug 27, 2012 | 12:12 PM
Andy-Custom Diesel's Avatar
FormerVendor
grid heater delete does not effect cab heater in any way. like stated above, the only purpose is to get the cylinder temp. to normal quicker and to assist on cold start ups. with these trucks and their egr system, soot accumulates on the grid causing a massive restriction. i recommend that if you want to retain the grid heater, as you are installing an egr delete remove the intake horn and clean the grid off. you can use a small screw driver and BE CAREFUL! do not damage the grid and also use a shop vac to keep the contaminates from dropping into the head while servicing.
there is no adjustments for the injectors....valves only. the spec will be on the sticker on your valve cover. you will need a set of feeler gauges and allen wrenches. there is a procedure for setting the valves. of you cant find it on here, pm me and i will get it for you.
2004LB7
29
Feb 29, 2016 06:00 PM
rtbcoop
Dec 30, 2014 02:13 AM
Nov 28, 2014 09:50 PM
SMatyac
Nov 28, 2014 03:58 PM
Nov 12, 2014 08:10 AM
