5.9 05' Cummins 3500
Old Jul 23, 2012 | 06:45 PM
jreanns's Avatar
Default 5.9 05' Cummins 3500
My AC system will not work even after i have recovered and charged the system. Does anybody know where to find a diagram for the whole system with parts placement included. Its summer time and hauling hay is not so nice when its hot!!!!
Old Jul 25, 2012 | 11:36 PM
Gerry R's Avatar
My 2001 did the same thing and turned out to be the compressor clutch not working. A reputable AC shop should figure it out in a few minutes. They're not very complicated.
Old Jul 26, 2012 | 08:37 AM
dangerous1965's Avatar
Compressor failure is high on these due to bad condensor cooling I'm going on my 3rd compressor! You have to have a Aux fan mounted on the condensor to cool it or you wil run into extremely high pressures that fry the compressor. If you charged the system that means the compressor is working 1lb 14oz of freon is all it needs! Did you replace the dryer and oriface tube? If not do it again! but make sure you have air blowing across the condensor!
Old Jul 26, 2012 | 10:49 AM
helton87's Avatar
another thing you may want to check, AFTER you get it working is your clutch fan. i had changed mine out because it had excessive wobble to it, and now when it idle's for a few mins and i take off i can definatly hear it! and before i heard nothing. so it may not be pulling enough air because the clutch is out and its not engaging the fan.
Old Jul 26, 2012 | 10:36 PM
TheOtherNick's Avatar
Make sure the clutch is engaging. If its not check for power at the clutch. If you have power there and its not running time for a new comp.
Old Jul 27, 2012 | 05:54 AM
Texascummins27's Avatar
If you end up haveing to replace the comp here is a link for a unit I just got for my 03. It comes with everything you need to do the job right. 2003-2005 DODGE RAM 2500/3500 5.9 DIESEL A/C COMPRESSOR REPAIR KIT | eBay
Old Jul 27, 2012 | 04:47 PM
jreanns's Avatar
Default Thank you
Thank you guys. I ordered a Temp. Sensor Switch not sure if it will do any good but i figured I would start with the cheapest easiest part and work my way up. But for sure if that doesnt work I will definatly see about the compressor and whatever else may be the problem.
Old Jul 31, 2012 | 06:06 PM
Just take it to a shop instead of guessing. Normally what I see is people throw $1000 in parts with out fixing the issue and we can diagnosis it fairly quickly and actually save you money.
nathanmueller
Diesel Engine Conversions
Sep 8, 2015 03:30 PM
bubbs33003
May 3, 2015 11:31 AM
plumberjack
29
Mar 3, 2015 11:38 PM
78F250Cummins
Wanted To Buy (WTB) - Used
Nov 9, 2014 01:12 AM
Dan7769
22
Nov 6, 2014 03:05 PM
