will it fit??
Old Jul 21, 2012 | 08:52 PM
lemonjello's Avatar
Default will it fit??
i found a 96 7.3 powerstroke for real cheap and im not sure if my truck will fit it . my truck is a 02 f350 , it currently has a 7.3 but like i said im not sure the connections and hoses are the same . i dont expect everything to be exactly the same but would like to know if it can be done and how much exttra work will i have to do to make it work. thanx a bunch
Old Jul 21, 2012 | 08:58 PM
1999stroker's Avatar
Why do you want to go to older motor? Is the one in your truck now shot? Jw.
Sent from my DROID BIONIC
Old Jul 21, 2012 | 09:15 PM
biged681985's Avatar
There is way to much to do to get a 96 to work in a new one
Old Jul 21, 2012 | 10:40 PM
fordornothing's Avatar
it can be done. but you have to transfer alot of things over. like turbo, injectors, wiring, intake parts...
Old Jul 22, 2012 | 02:36 AM
lemonjello's Avatar
the motor is older but has 150 000 on the clock for $400 where a 02 7.3 with 200+ miles goes for $1500. just thought it was worth a shot .i think my motor just needs to be rebuilt but i have to try the cheapest/easiest route .with my luck id spend alot of time tearing into my motor for rebuild purposes to find a crack somewhere no good and still have to buy a new one .
Old Jul 22, 2012 | 03:11 AM
joebob3093's Avatar
Moderator
all it would take it swapping a few parts over
Old Jul 22, 2012 | 09:11 AM
twinboys's Avatar
Who would swap parts to save $1100?
Old Jul 22, 2012 | 03:44 PM
lemonjello's Avatar
@ joebob ( or any body else), could you gimme a basic break down of the parts that may need to be switched aside from a couple of sensors. that would be great .tha
Old Jul 22, 2012 | 03:48 PM
if you look at my last post, i did...
Old Jul 22, 2012 | 04:18 PM
joebob3093's Avatar
Moderator
wiring is the biggest thing, then the turbo, intake plenums, uppipes, depending on the year maybe the drivers side manifold. the accessories on the front, as the alternator and AC pump is on the opposite sides.
