1993 ford e350 with 7.3 no turbo problem
Old Jul 20, 2012 | 01:07 PM
Paulieb's Avatar
Default 1993 ford e350 with 7.3 no turbo problem
Hello all I'm about to loose my mind with this truck. I bought truck about 7 years ago when I bought truck it had a one piece fuel filter it had a drain on the bottom of it. I replaced fuel filter from ford but they also sold me a bottom separator for the new filter. Weeks later I started to have a problem with the truck stalling. I brought the truck to ford and they changed injectors and injection pump. When I left ford the truck died on me. I decided to fix truck myself. I changed fuel pump on block and that didn't do it. Then I changed sending unit in tank and that worked truck ran great.
About a month ago I was driving truck and when I accelerated ithe fuel filter light came on. I changed the fuel filter. About two weeks ago the light came back on at acceleration but then the truck died it took a while to get it started again but it did I changed fuel filter again and same problem. The truck idles fine but on acceleration fuel filter light come on and dies. I checked sending unit in tank but it was clear. I blew air thru the lines and all seemed clear
Please help I'm out of options and don't trust non of these mechanics around here. It's a 1993 ford e350 with a 7.3 non turbo. Please help
Old Jul 20, 2012 | 03:15 PM
94turbostroker's Avatar
Did you check to see if you have any fuel leaks anywhere around your filter & pump & that stuff?
Old Jul 20, 2012 | 07:37 PM
Paulieb's Avatar
i do not see any leaks anywhere
Old Jul 21, 2012 | 01:41 PM
Cpdenton's Avatar
I am far from an expert, but have you had the lift pump checked, or changed recently?( I saw that it was done when you bought it) If the IP is not getting enough fuel to it, but enough to idle, it could cause this problem.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
fivo2fst4u
Aug 14, 2015 09:45 PM
fivo2fst4u
Jul 2, 2015 06:20 PM
tumble72
8
Nov 27, 2014 10:31 PM
